Hi, all
recently i’ve tried to play with auto unroll like that:
#define UNROLL 8
float V=A[tid];
for(j=0;j<C/UNROLL;j++){
for(i=0;i<UNROLL;i++){
V=V*0.1f+0.9f;
I see that inner loop is unrolled as follows:
mov.f32 %f3, 0f3f666666; // 0.9
mov.f32 %f4, 0f3dcccccd; // 0.1
mov.f32 %f5, 0f3f666666; // 0.9
mov.f32 %f6, 0f3dcccccd; // 0.1
mov.f32 %f7, 0f3f666666; // 0.9
mov.f32 %f8, 0f3dcccccd; // 0.1
mov.f32 %f9, 0f3f666666; // 0.9
mov.f32 %f10, 0f3dcccccd; // 0.1
mov.f32 %f11, 0f3f666666; // 0.9
mov.f32 %f12, 0f3dcccccd; // 0.1
mov.f32 %f13, 0f3f666666; // 0.9
mov.f32 %f14, 0f3dcccccd; // 0.1
mov.f32 %f15, 0f3f666666; // 0.9
mov.f32 %f16, 0f3dcccccd; // 0.1
mov.f32 %f17, 0f3f666666; // 0.9
mov.f32 %f18, 0f3dcccccd; // 0.1
mad.f32 %f19, %f18, %f2, %f17;
mad.f32 %f20, %f16, %f19, %f15;
mad.f32 %f21, %f14, %f20, %f13;
mad.f32 %f22, %f12, %f21, %f11;
mad.f32 %f23, %f10, %f22, %f9;
mad.f32 %f24, %f8, %f23, %f7;
mad.f32 %f25, %f6, %f24, %f5;
mad.f32 %f2, %f4, %f25, %f3;
and run time was 0.15 arb. units. Then i decided to pass 0.1 via argument dt in kernel call:
#define UNROLL 8
float V=A[tid];
V=V*dt+0.9f;
loop was unrolled but in some other way:
mad.f32 %f5, %f3, %f2, %f4;
mov.f32 %f6, 0f3f666666; // 0.9
mad.f32 %f7, %f3, %f5, %f6;
mov.f32 %f8, 0f3f666666; // 0.9
mad.f32 %f9, %f3, %f7, %f8;
mov.f32 %f10, 0f3f666666; // 0.9
mad.f32 %f11, %f3, %f9, %f10;
mov.f32 %f12, 0f3f666666; // 0.9
mad.f32 %f13, %f3, %f11, %f12;
mov.f32 %f14, 0f3f666666; // 0.9
mad.f32 %f15, %f3, %f13, %f14;
mov.f32 %f16, 0f3f666666; // 0.9
mad.f32 %f17, %f3, %f15, %f16;
mov.f32 %f18, 0f3f666666; // 0.9
mad.f32 %f2, %f3, %f17, %f18;
performance dropped to 0.18 arb. units! The only difference is common register %f3 which i suppose is the bottleneck for cuda core pipline. So i decided to write something like:
#define UNROLL 8
register FL_DBL a=dt;
register FL_DBL aa[16];
aa[0]=0.0f;
for(i=0;i<UNROLL;i++) aa[i]+=a;
for(j=0;j<C*D/UNROLL;j++){
V=V*aa[i]+0.9f;
It is different code but operations are the same. In ptx output I see:
mov.f32 %f35, 0f3f666666; // 0.9
mad.f32 %f36, %f34, %f2, %f35;
mov.f32 %f37, 0f3f666666; // 0.9
mad.f32 %f38, %f33, %f36, %f37;
mov.f32 %f39, 0f3f666666; // 0.9
mad.f32 %f40, %f32, %f38, %f39;
mov.f32 %f41, 0f3f666666; // 0.9
mad.f32 %f42, %f31, %f40, %f41;
mov.f32 %f43, 0f3f666666; // 0.9
mad.f32 %f44, %f30, %f42, %f43;
mov.f32 %f45, 0f3f666666; // 0.9
mad.f32 %f46, %f29, %f44, %f45;
mov.f32 %f47, 0f3f666666; // 0.9
mad.f32 %f48, %f28, %f46, %f47;
mov.f32 %f49, 0f3f666666; // 0.9
mad.f32 %f2, %f27, %f48, %f49;
No shared register! And performance increased again to 0.16 arb. units!
If UNROLL = 32 the performance differs greater! I think it is a problem of nvcc that for second code it uses only one register while for first code it uses UNROLL number of registers for one value. My question is how to make nvcc to use UNROLL number of registers for dt parameter?
Actually I address my question to nvcc developers. I’ve also locked through code that multiplies VV and code that multiplies V0.9f and found that first works slower due to mul.f32 %f2,$f1,%f1 while second code generates series of mov.32f %f2,0.9f and mul.32f %f3,%f2,%f1. I suppose second works faster because pipeline logic can’t efficiently load value from the one register. The second code doesn’t not uses same registers. Am I right? If so why not to create the code with different registers in mov.f32 for V*V C++ instruction.
The one thing that I still can’t understand if pipeline and ILP are the same? Why I do I need lots of warps with more overall threads that actually exists on my SM. Even if I will unroll my loops to 16, 32, 128 etc. operations i still need TLP, lots of warps etc.
