Hello, I’m new to cuda programming. When I learn cuda programming on udacity course, I encountered a problem when I write radix sort. here’s my answer on stackoverflow, could anyone can help me?
https://stackoverflow.com/questions/46170518/intro-to-parallel-programming-cs344
I suppose I found the bug in it.
Good, next time, be sure you are using the right syntax and non- depreciated sm version.
Hi zhangyule, can you still access to udacity cs344 now?
I tried to access to it, but failed.
https://developer.nvidia.com/udacity-cs344-intro-parallel-programming
“Enroll today”
Then it will goto “Courses and Nanodegree Programs”, but not found cs344.
