We developped a version of Yolo V3 on ONNX format to infer with TensorRT.
After the serialization of the model, randomly, we have this cuda error 1: [gatherRunner.cpp::execute::104] Error Code 1: Cuda Runtime (invalid configuration argument)
when the execution of the “enqueuev2” command.
This error appends with differents GPUs and on dfferents computers.
If you have any idea to help us to resolve our issue, thank you.
Environment
TensorRT Version: 8.0.0 GPU Type: 1080 - 20280 Ti Nvidia Driver Version: 465.19.01 CUDA Version: 11.3 CUDNN Version: 8.2.0.53 Operating System + Version: Ubuntu 18.04 (Docker) Python Version (if applicable): TensorFlow Version (if applicable): PyTorch Version (if applicable): Baremetal or Container (if container which image + tag): nvidia/cuda:11.3.0-cudnn8-devel-ubuntu18.04
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command. https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
Hi. Thanks for your answer.
Unfortunately, I cannot share my model because it is the property of my company.
I tried to use the snippet check_model.py and I have this issue :
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/onnx/checker.py", line 104, in check_model
C.check_model(protobuf_string)
onnx.onnx_cpp2py_export.checker.ValidationError: No Op registered for BatchedNMSDynamic_TRT with domain_version of 11
==> Context: Bad node spec for node. Name: onnx_graphsurgeon_node_0 OpType: BatchedNMSDynamic_TRT
Otherwise, the use of the trtexec command does not reveal any issue with my model.
