CUDA stream are blocked when luanch lots of kernels (>1000)
I found that CUDA stream will block when I launch lots of kernels (more than 1000). I am wondering is there any configuration that I can change?
In my experiments, I launch a small kernel 10000 times. This kernel ran shortly(about 190us). The kernel launched very fast when launching the first 1000 kernels. It takes 4~5us to launch a kernel. But after that, The launch process becomes slow. It takes about 190 us to launch a new kernel. The CUDA stream seems to wait for the previous kernel complete, and the buffer size is about 1000 kernels. When I created 3 streams, each stream can launch 1000 kernel asynchrony. I want to make this buffer bigger. I try to set cudaLimitDevRuntimePendingLaunchCount, but not work. Is there any way?
#include <stdio.h>
#include "cuda_runtime.h"
#define CUDACHECK(cmd) do {                         \
    cudaError_t e = cmd;                              \
    if( e != cudaSuccess ) {                          \
        printf("Failed: Cuda error %s:%d '%s'\n",             \
        __FILE__,__LINE__,cudaGetErrorString(e));   \
        exit(EXIT_FAILURE);                             \
} while(0)
// a dummy kernel for test
__global__ void add(float *a, int n) {
    int id = threadIdx.x + blockIdx.x * blockDim.x;
    for (int i=0; i<n; i++) {
        a[id] = sqrt(a[id] + 1);
int main(int argc, char* argv[])
    //managing 1 devices
    int nDev = 1;
    int nStream = 1;
    int size = 32*1024*1024;
//allocating and initializing device buffers
    float** buffer = (float**)malloc(nDev * sizeof(float*));
    cudaStream_t* s = (cudaStream_t*)malloc(sizeof(cudaStream_t)*nDev*nStream);
for (int i = 0; i < nDev; ++i) {
        CUDACHECK(cudaSetDevice(i));
        //CUDACHECK(cudaDeviceSetLimit(cudaLimitDevRuntimePendingLaunchCount, 10000));
        CUDACHECK(cudaMalloc(buffer + i, size * sizeof(float)));
        CUDACHECK(cudaMemset(buffer[i], 1, size * sizeof(float)));
        for (int j = 0; j<nStream; j++)
        CUDACHECK(cudaStreamCreate(s+i*nStream+j));
        for (int j=0; j<10000; j++) {
            for (int k=0; k<nStream; k++)
            add<<<32, 1024, 0, s[i*nStream+k]>>>(buffer[i], 1000);
        cudaDeviceSynchronize();
//free device buffers
        CUDACHECK(cudaFree(buffer[i]));
    printf("Success \n");
    return 0;
Here is the nvprof results:
When I create 3 streams, the first 3000 kernel launched quickly and then become slow
When I create 1 streams, the first 1000 kernel launched quickly and then become slow
I also create a stackoverflow question: https://stackoverflow.com/questions/53970187/cuda-stream-are-blocked-when-luanch-lots-of-kernels-1000
What you are seeing is expected behavior. The GPU command queue has finite length, but it is pretty generous in size. What are you hoping to achieve at application level by queuing up even more launches than you are doing now? Based on your description, your application’s throughput appears to be hopelessly bottlenecked on the GPU already: the host is submitting new kernels to the GPU at 40x the GPU kernel processing rate.
I was always under the impression that there is a command buffer size limit baked into the driver (which may change with driver version). So I can’t help you with the configuration aspect, as I have never noticed or explored it. What status does the call to cudaSetDeviceLimit return?
cudaLimitDevRuntimePendingLaunchCount pertains to device kernel launches, which are not in view in OP’s code. I’m not surprised it has no effect.
I’m not aware of any direct/explicit user configuration control over the host launch queue depth.
Thanks for the reply. I file a feature request on the bug report page.
