I have implemented the following class using CUDA streams
class CudaStreams
private:
int nStreams_;
cudaStream_t* streams_;
cudaStream_t active_stream_;
public:
// default constructor
CudaStreams() { }
// streams initialization
void InitStreams(const int nStreams = 1) {
nStreams_ = nStreams;
// allocate and initialize an array of stream handles
streams_ = (cudaStream_t*) malloc(nStreams_*sizeof(cudaStream_t));
for(int j = 0; j < nStreams_; j++) CudaSafeCall(cudaStreamCreate(&(streams_[j])));
active_stream_ = streams_[0];}
// default destructor
~CudaStreams() {
for(int j = 0; j<nStreams_; j++) CudaSafeCall(cudaStreamDestroy(streams_[j])); }
If I now run this simple code
void main( int argc, char** argv)
streams.InitStreams(1);
streams.~CudaStreams();
cudaDeviceReset();
cudaDeviceReset();
after the cudaDeviceReset() call, I receive the following message:
Unhandled exception 0x772f15de in test.exe: 0x00000000.
What should I do before invoking the destructor to avoid this issue when using cudaDeviceReset()?
