is the cudamemsync blocking? if so for better performance using async mem copy with stream. when do I need to sync the result? (when everything in GPU is done and handover result back to CPU)? for example if I use async copy->fft->mult->ifft->syncstream->copy result back to host?
Related topics
| Asyncronus call | 1 | 2345 | September 24, 2009 | |
| Async questions Kernels appear to stall host threads | 3 | 2390 | January 20, 2008 | |
| Much slower async memcpy in a separate stream than in stream 0 | 4 | 5326 | July 23, 2015 | |
| Are cudaMemCpy and cudaMalloc blocking/synchronous? | 1 | 1137 | September 30, 2024 | |
| Memset/memcpyDtoD implicitly synchronizes all streams -- a way to disable it? | 5 | 813 | August 23, 2023 | |
| influence of muti-threading in cudaMemCpy? | 6 | 853 | October 26, 2018 | |
| cudaMemcpyAsync problem | 9 | 3477 | May 26, 2020 | |
| A general question on Cuda Sync after kernal call | 2 | 485 | January 22, 2023 | |
| cudaMemcpyAsync not giving any answers using cudaMemcpyAsync function | 1 | 879 | September 5, 2011 | |
| Memory copy/set async to kernel execution in different stream | 5 | 1378 | December 15, 2022 |
