CUDA with Matlab - nvmex throws error with cl.exe
i am quite new to CUDA and MEX-Programming, so i tried Readme.txt, involved in Matlab-package for CUDA.
Building with mex works fine. Unfortunatly, nvmex wont.
I tried ‘-f nvmexopts.bat Szeta.cu -IG:\cuda\include -LG:\cuda\lib -lcufft -lcudart’, as shown in readme.
First it thorws: >> Undefined subroutine &main::uuidgen called at E:\Matlab\R2008a\bin\nvmex.pl line 728.
I thought, well ok, whats about round(10000*rand()) ? Ok, dont work, cause it’s pearl. I also dont know anything of pearl, so typed ‘100’ for my uuID.
now it says: nvcc fatal : Cannot find compiler ‘cl.exe’ in PATH
Well, i have VC8 (2005), added all paths, containing a cl.exe (after \VC\bin only wont work), but it everytime says the same.
How do i start nvcc ?
Thanks in Advantage and please excuse my bad english !
mex -setup should be run before as far as I remember to set up the paths for cl.exe within matlab.
Don’t work anyway. It prints me out, to use MS Visual 8, but can’t find pl.exe.
Ah, i got it: it’s in “nvmexopts.bat”:
nvcc suggests, my VC is in partition C: - but not on my system :ph34r:
edited, and it works. (so error was in batch, not in Matlab)
<img src=‘http://hqnveipbwb20/public/style_emoticons/<#EMO_DIR#>/crying.gif’ class=‘bbc_emoticon’ alt=‘:’(’ /> but it won’t work.
Compiler says:
g:\cuda\include\common_functions.h(56): warning: dllexport/dllimport conflict with “clock”
G:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\time.h(176): here; dllimport/dllexport dropped
cl : Command line warning D9025 : overriding ‘/EHc-’ with ‘/EHc’
After trying to start FS_2Dturb with new Szeta, Matlab crashes down.
After a new compile everything works ! (except the uuid() in pearlscript [and wtf is my pearlinterpreter?])
Andy,
I have the similar problem. Compiler said the same warnings, and after trying to start FS_2Dturb with new Szeta Mathlab said
??? Invalid MEX-file ‘F:\RDE\Matlab_CUDA_1.1\Szeta.mexw32’: The specified module could not be found.
Error in ==> FS_2Dturb at 89
  d1 = dt*Szeta(zeta,k,nu4);
How did you make it worked?
