Can anyone share insight into why the following program crashes when copying the array of bools d_unique from device to host, after initialization by the the kernel.
My GPU is Quadro K1000M (mobile) with compute capability 3.0. CUDA version 8.
#include <iostream>
// nvcc -ccbin g++ -g -m64 -gencode arch=compute_30,code=sm_30 -o Bug Bug.cu
// Helper Functions Decl
void allocateDeviceMemory( void* devPtr , unsigned size , int lineNumber );
void copyDataToHost( void* hostPtr , void* devPtr , unsigned size , int lineNumber );
void copyDataToDevice( void* devPtr , void* hostPtr , unsigned size , int lineNumber );
void initializeDeviceMemory( void* devPtr , unsigned size , unsigned initValue , int lineNumber );
__global__ void myKernel( const ushort* __restrict__ dataPtr , const ushort* __restrict__ proxyId , bool* unique , unsigned size , const ushort dim )
int N = threadIdx.x + ( blockIdx.x * blockDim.x );
if( N < size - 1 )
unsigned offset;
ushort countPtr = 0;
ushort id1 = proxyId[N];
ushort id2 = proxyId[N + 1];
for( ushort i = 0; i < dim; ++i )
if( dataPtr[offset + id1] == dataPtr[offset + id2] ) ++countPtr;
offset += size;
unique[N + 1] = ( countPtr != dim ); // No crash if commented out
int main(int argc, char** argv)
ushort dim = 2;
static const unsigned SIZE = 10;
ushort h_proxyId = { 6 , 3 , 1 , 0 , 7 , 4 , 2 , 8 , 5 , 9 };
ushort h_dataPtr[ 2 * SIZE] = { 1 , 1 , 2 , 1 , 2 , 3 , 1 , 2 , 3 , 4 ,
4 , 3 , 3 , 2 , 2 , 2 , 1 , 1 , 1 , 1 };
bool* d_unique = 0;
ushort* d_proxyId = 0;
ushort* d_dataPtr = 0;
allocateDeviceMemory( &d_proxyId , SIZE * sizeof(ushort) , __LINE__ );
allocateDeviceMemory( &d_dataPtr , SIZE * sizeof(ushort) * 2 , __LINE__ );
copyDataToDevice( d_proxyId , h_proxyId , SIZE * sizeof(ushort) , __LINE__ );
copyDataToDevice( d_dataPtr , h_dataPtr , SIZE * sizeof(ushort) * 2 , __LINE__ );
allocateDeviceMemory( &d_unique , SIZE , __LINE__ );
initializeDeviceMemory( d_unique , SIZE , 1 , __LINE__ );
myKernel<<<1,SIZE>>>( d_dataPtr , d_proxyId , d_unique , SIZE , dim ); // No crash if commented out
bool* h_unique = new bool;
copyDataToHost( h_unique , d_unique , SIZE , __LINE__ ); // Crashes here
return 0;
// Helper Functions Impl
cudaError_t error = cudaMalloc( (void**) devPtr , size );
if( error != cudaSuccess )
std::cout << "[Line " << lineNumber << " -- Error " << error << " : Unable to allocate device memory] " << cudaGetErrorString( error ) << std::endl;
exit(-1);
cudaError_t error = cudaMemset( devPtr , initValue , size );
std::cout << "[Line " << lineNumber << " -- Error " << error << " : Unable to initialize device memory to default value] " << cudaGetErrorString( error ) << std::endl;
exit(-1);
cudaError_t error = cudaMemcpy( hostPtr , devPtr , size , cudaMemcpyDeviceToHost );
std::cout << "[Line " << lineNumber << " -- Error " << error << " : Unable to copy device data to host memory] " << cudaGetErrorString( error ) << std::endl;
exit(-1);
cudaError_t error = cudaMemcpy( devPtr , hostPtr , size , cudaMemcpyHostToDevice );
std::cout << "[Line " << lineNumber << " -- Error " << error << " : Unable to copy host data to device memory] " << cudaGetErrorString( error ) << std::endl;
exit(-1);
cuda-memcheck yields no information, i.e.
ThinkPad-W530:~/tmp/CUDA/Prototype$ cuda-memcheck ./Bug
========= CUDA-MEMCHECK
[Line 59 -- Error 4 : Unable to copy device data to host memory] unspecified launch failure
========= Internal error (7)
========= No CUDA-MEMCHECK results found
