I’m using a cudaArray to store data and I bind it to a texture.
While the program is running, there’s no problem. Everything is fine.
After the program finishes the computation, a cleanup function calls
cudaFreeArray and I always get the an “Invalid argument”.
The CUDA doc says: “If cudaFreeArray(array) has already been called before, cudaErrorInvalidValue is returned.”
But there is no previous call to cudaFreeArray.
Here is some code:
cudaArray *tdataArray;
texture<float4, 1, cudaReadModeElementType> tdata;
void init()
cutilSafeCall(cudaMallocArray(&tdataArray, &channelData, h_dataLength.x, 1));
cutilSafeCall(cudaMemcpyToArray(tdataArray, 0, 0, data, h_dataLength.x * sizeof(float4), cudaMemcpyHostToDevice));
cutilSafeCall(cudaBindTextureToArray(tdata, tdataArray, channelData));
void cleanup()
cutilSafeCall(cudaFreeArray(tdataArray));
cutilSafeCall(cudaUnbindTexture(tdata));
I would be very appreciate, if someone can help me figuring out whats the problem.
