I am using Cuda SDK 4.0 and am encountering an issue which has taken me 2 days to whittle down into the following code.
#include <cuda.h>
#include <cuda_runtime.h>
void main (int argc, char ** argv) {
int* test;
cudaError_t err;
err = cudaSetDevice( 1 ); err = cudaMallocHost(&test, 1024*sizeof(int));
err = cudaSetDevice( 0 ); err = cudaFreeHost(test);
This throws the following error when calling cudaFreeHost:
First-chance exception at 0x000007fefd96aa7d in Test.exe: Microsoft C++ exception: cudaError_enum at memory location 0x0022f958..
The err value is cudaErrorInvalidValue
The same error occurs for this variation:
err = cudaSetDevice( 0 ); err = cudaMallocHost(&test, 1024*sizeof(int));
err = cudaSetDevice( 1 ); err = cudaFreeHost(test);
The following variations dont throw the error:
and
I was under the impression you only needed to call cudaSetDevice if you want to allocate memory on a specific GPU. In the above example I am only allocating pinned memory on the CPU.
Is this a bug or did I miss something in the manual?
(I have posted the same question in StackOverflow here:
