cudaFuncGetAttributes return unexpected result
I am trying to use cudaFuncGetAttributes to get the information about memory usage of a function. However, it returns unexpected result.
Here is my kernel:
[codebox]global void compute_pixel_value(unsigned char* image, float* pixel_value, float* min_max, int x_size, int y_size)
int idx = blockIdx.x*blockDim.x+threadIdx.x;
int idy = blockIdx.y*blockDim.y+threadIdx.y;
//To compute laplacian of a pixel, it need 8 neighbors -> need to check range.
if( (idx>0 && idx<x_size-1) && (idy > 0 && idy < y_size-1) )
	int index = idx + idy*x_size; // current pixel for this thread
	int i,j;
	int weight[3][3] = {{ 1,  1,  1 },
			  { 1,  -8,  1 },
			  { 1,  1,  1 }};
	for (j = - 1; j < 2; j++)
		for (i = -1; i < 2; i++)
		  int index_t = (idy+j)*x_size + idx + i;
		  pixel_value[index] += weight[j + 1][i + 1] * image[index_t];
	if (pixel_value[index] < min_max[0]) min_max[0] = pixel_value[index]; // min = min_max[0]
	if (pixel_value[index] > min_max[1]) min_max[1] = pixel_value[index];
[/codebox]
and calling of cudaFuncGetAttributes:
[codebox]void print_func_attr(struct cudaFuncAttributes at)
printf("Constant memory in bytes: %lu\n", at.constSizeBytes);
printf("Local memory in bytes: %lu\n", at.localSizeBytes);
printf("Max Thread per Block: %d\n", at.maxThreadsPerBlock);
printf("Number of registers used: %d\n", at.numRegs);
printf("Shared memory in bytes: %lu\n", at.sharedSizeBytes);
int main()
struct cudaFuncAttributes attr;
const char* fname = “compute_pixel_value”;
cudaFuncGetAttributes(&attr, fname);
print_func_attr(attr);
return 0;
}[/codebox]
Here is the result:
[codebox]Constant memory in bytes: 4270390
Local memory in bytes: 238895010520
Max Thread per Block: -1637762112
Number of registers used: 55
Shared memory in bytes: 6395888
[/codebox]
I spent a couple of hours to debug but no progress. I really appreciate if anyone can point out the problem in my code.
Thanks a lot,
Huynh.
I had the same problem.
You have called the cudaFuncGetAttributes function with the name of the kernelfunction as string. Like this:
cudaFuncGetAttributes(&attr, “compute_pixel_value”);
But you must give the funktionname not as string. You schould give it like you want to call the funktion.
cudaFuncGetAttributes(&attr, compute_pixel_value);
You can prefer if it’s called right with cudaGetLastError() and cudaGetErrorString().
as this is not well documented in the CUDA API,
the function takes as second parameter the compiled entry function name as string.
For example the PTAX compiler output shows that name:
ptxas info : Compiling entry function ‘_Z10fimIterateIdLj8EEvPKT_PKiPS0_PiS0_S0_S0_jjji’ for ‘sm_10’
ptxas info : Used 35 registers, 1956+0 bytes smem, 104 bytes cmem[0], 4 bytes cmem[16]
The determined attributes seems not be accurate to me with the compiler infos, but the maxThreadsPerBlock attribute is acceptable to use.
Maybe this is caused by compiling for architecture 1.0 , but running on a 2.1 capable device.
