cudaHostAlloc question
I’m profiling this code and I see that every odd allocation of 1MB of pinned memory takes 600-800us, while every even allocation takes 4-5us.
Compiling it like this and then running with nvprof:
nvcc -m64  -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_60,code=compute_60 -lnvToolsExt host_malloc.cu  -o cudaHostAllocTest
Any idea why this is happening?
#include "cuda_runtime.h"
#include "nvToolsExt.h"
#include <stdio.h>
#include <iostream>
using namespace std;
const uint32_t colors[] = { 0xff00ff00, 0xff0000ff, 0xffffff00, 0xffff00ff, 0xff00ffff, 0xffff0000, 0xffffffff };
const int num_colors = sizeof(colors)/sizeof(uint32_t);
int main()
	cout << "Main" << std::endl;
	const int N = 1000;
	const size_t ALLOCATION_SIZE = 1024 * 1024;
	int *data[N];
	// Just to warm up the cuda runtime.
	int *pdummy;
	cudaMalloc((void **)&pdummy, 4);
	char name[100];
	nvtxEventAttributes_t eventAttrib;
	for (int i = 0; i < N; i++)
		int color_id = i;
		color_id = color_id % num_colors;
		eventAttrib.colorType = NVTX_COLOR_ARGB;
		eventAttrib.color = colors;
		eventAttrib.messageType = NVTX_MESSAGE_TYPE_ASCII;
		sprintf(name, "cudaHostAlloc.%d", i);
		eventAttrib.message.ascii = name;
		nvtxRangePushEx(&eventAttrib);
		cudaHostAlloc(&(data[i]), ALLOCATION_SIZE, cudaHostAllocPortable);
		nvtxRangePop();
		data[i][i % 10] = i;
		cudaFreeHost(data[i]);
	cudaDeviceReset();
	return 0;
Just to add:
This is what nvprof gives to 2MB buffers:
Time(%) Time Calls Avg Min Max Name
52.62% 349.47ms 500 698.94us 540.46us 983.58us cudaHostAlloc
[b]4MB:[/b]
56.69% 531.37ms 500 1.0627ms 897.13us 1.3280ms cudaHostAlloc
[b]And for 64MB:[/b]
47.39% 636.98ms 50 12.740ms 12.081ms 16.595ms cudaHostAlloc
I wouldn’t be surprised if there is some kind of underlying allocation granularity of 2MB. The even/odd variability goes away at 2MB size. If you switch to 0.5MB you see a 1-long 3-short repeating pattern. The host operating system may pin 2MB and then use that for allocations until it is exhausted. Or it may be that CUDA is doing that. You see a similar pattern in the cudaFreeHost calls also. This suggests to me that it is not CUDA but the host OS that is doing the quantization.
Thanks a lot Robert!
