I thought you said you had it working here:
Related topics
| Share GPU/host pinned memory between host processes | 5 | 4281 | March 7, 2012 | |
| cudaIpcGetMemHandle can not use ptr created by cudaMallocManaged | 1 | 160 | April 15, 2025 | |
| Why exporting and importing CUDA IPC handles in the scope of the same Linux process is not supported? | 7 | 1394 | May 10, 2023 | |
| PyCUDA pass pointers to GPU memory | 5 | 2205 | December 31, 2020 | |
| GPU Inter-Process Communications(IPC) question | 13 | 16243 | January 4, 2023 | |
| cuIpcGetMemHandle in 32-bit Application | 3 | 868 | February 18, 2023 | |
| Registering POSIX-CPU shared memory to CUDA with cudaHostRegister | 4 | 604 | July 16, 2024 | |
| can I use pinned memory? | 6 | 2812 | September 21, 2009 | |
| cuIpcOpenMemHandle return CUDA_ERROR_INVALID_CONTEXT | 2 | 1481 | July 25, 2022 | |
| mmap and pinned memory How to share a pinned buffer between several linux processes ? | 1 | 1887 | August 2, 2011 |
