cudaLaunchHostFunc + cudaEventElapsedTime?
Hey all. I’d like to asynchronously calculate the duration of an async kernel launch or async copy.
I could use events, but I don’t want to synchronize on an event and stall anything. I could capture CPU time before the launch, and again in cudaLaunchHostFunc, but that time will also include any queuing time.
It seems like it may be an ideal combination to do:
void recordScope(void *datav) {
  float millis;
  cudaEventElapsedTime(&millis, data.start, data.stop));
cudaEventRecord(data.start);
launch();
cudaEventRecord(data.stop);
cudaLaunchHostFunc(recordScope, &data);
Unfortunately, the documentation for cudaLaunchHostFunc states that no cuda calls should be made within the callback. Does that apply to cudaEventElapsedTime as well? Are there other ways to do what I want?
Yes
I haven’t noticed much difference between proper CPU timing of a kernel launch and the proper use of cudaEvent based method along the lines of what you have shown.
Of course you could wait until some other necessary synchronization. But you’re specifically asking about not that.
The only other idea I have would be to spin up additional thread(s), and use interthread signaling using e.g. a semaphore, so that the callback signals your waiting thread to go ahead and compute the cudaEventElapsedTime. That seems like an awful lot of machinery.
Perhaps others will have better ideas.
Thanks. What you said makes sense, though I’d expect some differences between host timing before launch and after since I’m running many things on many streams. It strikes me that I should be able to use cudaLaunchHostFunc before and after the launch, e.g.
cudaLaunchHostFunc(recordScope, &dataStart);
launch();
cudaLaunchHostFunc(recordScope, &dataEnd);
It does mean maintaining a fair amount of bookkeeping, and I’m unsure what the overheads are of asking CUDA to call my callback, but otherwise, this seems like it should work. Opinions?
If it were me, I would not use a callback for timing:
$ cat t2084.cu
#include <iostream>
#include <time.h>
#include <sys/time.h>
#define USECPSEC 1000000ULL
const unsigned long long my_delay = 1000000ULL;
unsigned long long dtime_usec(unsigned long long start=0){
  timeval tv;
  gettimeofday(&tv, 0);
  return ((tv.tv_sec*USECPSEC)+tv.tv_usec)-start;
__global__ void k(unsigned long long delay){
  unsigned long long start = clock64();
  unsigned long long end = start+delay;
  while (clock64() < end);
struct d{
  unsigned long long start;
} my_parms;
void dt_cpu(void *parms){
  d *p = (d *) parms;
  std::cout << "CB Duration: " << dtime_usec(p->start) << "us" << std::endl;
int main(){
  cudaEvent_t start, stop;
  cudaEventCreate(&start);
  cudaEventCreate(&stop);
  cudaStream_t s;
  cudaStreamCreate(&s);
  k<<<1,1, 0, s>>>(my_delay); // warm-up
  cudaDeviceSynchronize();
#if defined USE_EVENT
  cudaEventRecord(start, s);
#elif defined USE_CB
  my_parms.start = dtime_usec(0);
#else
  unsigned long long scpu = dtime_usec(0);
#endif
  cudaEventRecord(stop, s);
  cudaEventSynchronize(stop);
  float ms;
  cudaEventElapsedTime(&ms, start, stop);
  std::cout << "EV Duration: " << (ms*1000) << "us" << std::endl;
  cudaLaunchHostFunc(s, dt_cpu, &my_parms);
#else
  std::cout << "CPU Duration: " << dtime_usec(scpu) << "us" << std::endl;
#endif
$ nvcc -o t2084 t2084.cu
$ ./t2084
CPU Duration: 880us
$ nvcc -o t2084 t2084.cu -DUSE_EVENT
$ ./t2084
EV Duration: 823.84us
$ nvcc -o t2084 t2084.cu -DUSE_CB
$ ./t2084
CB Duration: 1096us
CUDA 11.4, V100, CentOS7
About 99% of the time I use timing measurements like this for comparative purposes, e.g. to test the benefit of a presumed optimization. In that case, for the first two methods (not callback), it seems that they can “resolve” a ~1% change in kernel duration (for this test case). Modifying the code to:
const unsigned long long my_delay = 1010000ULL;
I get the following output:
$ ./t2084
CPU Duration: 896us
$ ./t2084
EV Duration: 827.52us
$ ./t2084
CB Duration: 1083us
For completeness, nvprof reports for the original duration:
$ nvprof ./t2084
==7309== NVPROF is profiling process 7309, command: ./t2084
CPU Duration: 874us
==7309== Profiling application: ./t2084
==7309== Profiling result:
            Type  Time(%)      Time     Calls       Avg       Min       Max  Name
 GPU activities:  100.00%  1.6225ms         2  811.24us  811.16us  811.32us  k(__int64)
and for the 1% increased duration:
$ nvprof ./t2084
==6697== NVPROF is profiling process 6697, command: ./t2084
CPU Duration: 879us
==6697== Profiling application: ./t2084
==6697== Profiling result:
 GPU activities:  100.00%  1.6386ms         2  819.32us  819.22us  819.41us  k(__int64)
YMMV
Thanks for the thorough investigation. This gives me a good place to start.
