I’m trying to increase performance in some code, and after improving kernel times significantly (according to Nsight Compute), at the expense of a few more kernel calls, run time only increased.
I tried Nsight Systems (for the first time), and I get something that looks suspicious when I look at the CUDA summary in the stats system view. Here are the three top lines:
Time Total Time Instances Avg Med Min Max StdDev Category Operation
81.2% 42.985 s 8717 4.931 ms 2.740 ms 5.600 μs 29.521 ms 4.677 ms CUDA_API cudaLaunchKernel
14.5% 7.704 s 3433 2.244 ms 1.026 ms 855.836 μs 10.104 ms 2.818 ms CUDA_KERNEL void Kernels::Update...
1.2% 626.529 ms 4156 150.753 μs 69.666 μs 64.226 μs 877.150 μs 205.191 μs CUDA_KERNEL void Kernels::Copy...
Can someone explain to me what’s going on?
Edit: This is being run on a laptop with a Ryzen 7 5800H, GeForce 3080 16GB, 64GB system RAM, Windows 10. I’m using CUDA 11.4.
