Hi -
I believe I am encountering an error on cudaMalloc that I’m having trouble tracking down the cause.
Here’s a quick description of the algorithm:
main() has a long loop, anywhere from 200-500 iterations
each iteration calls 4 GPU kernels
for each kernel call, device memory is allocated and freed
for each kernel, there is a host-device and then a device-host transfer
The problem:
- around 300 iterations there is an “unknown error” returned by cudaMalloc causing “invalid device pointer” error on subsequent cudaMemcpy calls
Other symptoms:
the GPU crash occurs for a certain dataset size and above (28MBx7=~200MB); the kernel it crashes in allocates 7 arrays of 28MB.
the error returned is apparently not “cudaErrorMemoryAllocation” and is only caught with cudaGetLastError()
there seems to be enough free memory before the cudaMalloc call (via cuMemGetInfo())
System Info:
Hardware: nVidia GTX 8800
cuda version: 1.1
OS: Win XP
Questions:
hints what may be causing the crash?
instead of allocating device memory each iteration, it is possible to allocate the device memory once before the loop? since I have 4 separate kernel calls, are there any restrictions with this approach? (ie: are the device pointers still valid after each kernel exits).
// 0. Memory allocation
// device allocation
CUDA_SAFE_CALL( cudaMalloc( (void **)&d_u1, nDataSizeBytes ) );
CUDA_SAFE_CALL( cudaMalloc( (void **)&d_u2, nDataSizeBytes ) );
CUDA_SAFE_CALL( cudaMalloc( (void **)&d_u3, nDataSizeBytes ) );
CUDA_SAFE_CALL( cudaMalloc( (void **)&d_f1, nDataSizeBytes ) );
CUDA_SAFE_CALL( cudaMalloc( (void **)&d_f2, nDataSizeBytes ) );
CUDA_SAFE_CALL( cudaMalloc( (void **)&d_f3, nDataSizeBytes ) );
// CUDA_SAFE_CALL( cudaMalloc( (void **)&d_J, nDataSizeBytes ) );
cudaError_t error;
cuMemGetInfo( &nFree, &nTotal );
printf("dlGPUEvaluate_f_MI (malloc7): nFree= %d nTotal=%d\n", nFree, nTotal );
error = cudaMalloc( (void **)&d_J, nDataSizeBytes );
// if( error == cudaErrorMemoryAllocation )
if( cudaCheckErrors() )
printf("Cuda Error in dlGPUEvaluate_f_MI()!: cudaMalloc 7: nDataSizeBytes= %d\n", nDataSizeBytes );
// setup interp grid params
float pGridParams[6];
pGridParams[ GRID_DX_INV ] = 1.f / dx;
pGridParams[ GRID_DY_INV ] = 1.f / dy;
pGridParams[ GRID_DZ_INV ] = 1.f / dz;
pGridParams[ GRID_DX2_INV ] = 1.f / (2*dx);
pGridParams[ GRID_DY2_INV ] = 1.f / (2*dy);
pGridParams[ GRID_DZ2_INV ] = 1.f / (2*dz);
int pDimParams[3];
pDimParams[ X ] = nWidth;
pDimParams[ Y ] = nHeight;
pDimParams[ Z ] = nDepth;
// 1. Copy data from host to device
CUDA_SAFE_CALL( cudaMemcpy( d_u1, h_u1, nDataSizeBytes, cudaMemcpyHostToDevice ) );
CUDA_SAFE_CALL( cudaMemcpy( d_u2, h_u2, nDataSizeBytes, cudaMemcpyHostToDevice ) );
CUDA_SAFE_CALL( cudaMemcpy( d_u3, h_u3, nDataSizeBytes, cudaMemcpyHostToDevice ) );
CUDA_SAFE_CALL( cudaMemcpy( d_f1, h_f1, nDataSizeBytes, cudaMemcpyHostToDevice ) );
CUDA_SAFE_CALL( cudaMemcpy( d_f2, h_f2, nDataSizeBytes, cudaMemcpyHostToDevice ) );
CUDA_SAFE_CALL( cudaMemcpy( d_f3, h_f3, nDataSizeBytes, cudaMemcpyHostToDevice ) );
printf("Cuda Error in dlGPUEvaluate_f_MI()!: cudaMemcpy: host-to-device\n" );
CUDA_SAFE_CALL( cudaMemcpyToSymbol( d_GridF, pGridParams, 6*sizeof( float ) ) );
CUDA_SAFE_CALL( cudaMemcpyToSymbol( d_DimF, pDimParams, 3*sizeof( int ) ) );
CUDA_SAFE_CALL( cudaMemcpyToSymbol( d_lambda, &lambda, sizeof( float ) ) );
printf("Cuda Error in dlGPUEvaluate_f_MI()!: cudaMemcpyToSymbol\n" );
// 2. Setup CUDA kernel params
dim3 blockGrid( iDivUp( nDepth, BLOCKWIDTH_MI), iDivUp( nHeight, (BLOCKHEIGHT-2*PAD) ) );
dim3 threadBlock( PAD_ALIGNED+BLOCKWIDTH_MI+8, BLOCKHEIGHT );
// 3. Compute f
evaluate_f_MI<<<blockGrid, threadBlock >>>(
d_u1, d_u2, d_u3,
d_f1, d_f2, d_f3, d_J );
// 4. Copy results from device to host
CUDA_SAFE_CALL( cudaMemcpy( h_f1, d_f1, nDataSizeBytes, cudaMemcpyDeviceToHost) );
CUDA_SAFE_CALL( cudaMemcpy( h_f2, d_f2, nDataSizeBytes, cudaMemcpyDeviceToHost) );
CUDA_SAFE_CALL( cudaMemcpy( h_f3, d_f3, nDataSizeBytes, cudaMemcpyDeviceToHost) );
CUDA_SAFE_CALL( cudaMemcpy( h_J, d_J, nDataSizeBytes, cudaMemcpyDeviceToHost) );
printf("Cuda Error in dlGPUEvaluate_f_MI()!: cudaMemcpy: device-to-host\n" );
// 5. evaluate SKL
// reuse previously allocated memory for SKL
float *d_SKL = d_u1;
// setup kernel params
blockGrid = dim3( iDivUp( nDepth, BLOCKWIDTH_SKL), iDivUp( nHeight, BLOCKHEIGHT_SKL ) );
threadBlock = dim3( BLOCKWIDTH_SKL, BLOCKHEIGHT_SKL );
// copy constant from host to device
float fSKL_default = (.001f-1.f) * logf( .001f );
CUDA_SAFE_CALL( cudaMemcpyToSymbol( d_SKL_default, &fSKL_default, sizeof( float ) ) );
// compute SKL per voxel
evaluate_SKL<<< blockGrid, threadBlock >>>(
d_J, d_SKL
// sum SKL
dlCUDASumNPOT( fSKL, d_SKL, d_J, nDataSize );
printf("Cuda Error in dlGPUEvaluate_f_MI()!: SKL\n" );
// clean up
CUDA_SAFE_CALL( cudaFree(d_u1) );
CUDA_SAFE_CALL( cudaFree(d_u2) );
CUDA_SAFE_CALL( cudaFree(d_u3) );
CUDA_SAFE_CALL( cudaFree(d_f1) );
CUDA_SAFE_CALL( cudaFree(d_f2) );
CUDA_SAFE_CALL( cudaFree(d_f3) );
CUDA_SAFE_CALL( cudaFree(d_J) );
Output:
dlGPUEvaluate_f_MI (malloc7): nFree= 558338048 nTotal=804978688
Cuda error: unknown error
Cuda Error in dlGPUEvaluate_f_MI()!: cudaMalloc 7: nDataSizeBytes= 28311552
dlGPUEvaluate_f_MI (malloc7): nFree= 530026496 nTotal=804978688
Cuda error: invalid device pointer
