CudaMalloc() makes page-locked memory fail simple variable assignement
I’ve a problem with page-locked memory.
passing a pointer to device memory in my kernel
the assignment fails and *h_value remains 0
otherwhise, removing the cudaMalloc instruction and
removing the parameters passed to the kernel everything
goes fine.
What could be the problem?
thank’s
[codebox]
void my_function(void){
    /****INIT*****/
int *h_value = NULL;
int *d_value = NULL;
    int size=1024;
dim3 block(1,1);
dim3 grid(1,1);
/ALLOCATION*/
    cudaMalloc((void**)&d_input_data, size); // **** This line makes kernel increment fail! ******
cudaSetDeviceFlags(cudaDeviceMapHost);
cudaHostAlloc((void**) &h_value, sizeof( int ) , cudaHostAllocMapped | cudaHostAllocPortable);
cudaHostGetDevicePointer( &d_value , h_value , 0 );
    //init value on host
*h_value=0;
my_kernel<<<grid,block>>>( d_input_data , d_value );
printf("h_value = %d \n",*h_value);
[/codebox]
[codebox]global void ky_kernel( char* device_array, int *value )
*value=1;
[/codebox]
