Im trying to copy a linked list on to the GPU. Lets say I have a simple struct called Cuda. Can I make an array for Cuda pointers and malloc them on to the GPU?
typedef struct _Cuda
int value;
double leftovers;
struct _Cuda *nextCuda;
}Cuda;
typdef struct _Cuda1
int remove;
Cuda *firstnode;
Cuda *lastnode;
double max;
}Cuda1;
It would be nice to have that capability. But if there is some cuda restrictions its ok. I’m essentially trying to create a benchmark with command line arguments. So the node are specified at the command line. Also when I took a GPU computing course they mentioned that resursion is restricted. Will this prevent me from porting my single linked list to the GPU?
