cudaMemcpy DeviceToDevice and L2 cache usage
Hello!
There are a couple of posts, claiming that when using cudaMemcpy for Host-Device transfer, it is done through the GPU L2 cache:
https://forums.developer.nvidia.com/t/cudamemcpy-and-l2-cache/42817
https://stackoverflow.com/questions/34005844/gpu-l2-cache-hit-is-100-and-dram-load-transactions-sometimes-is-0
I was wondering if that’s the case when cudaMemcpy is used in a DeviceToDevice model in the same GPU, i.e using cudaMemcpy to copy from array A to array B, with A and B residing in GPU memory.
Thank you for your help!
I would be curious about this as well! Any updates on this?
I think it should be possible to test. Run nsight compute, make sure to provide the proper cache invalidation override options to nsight compute, then look at a hit metric.
If you are looking for documentation, I don’t think it is documented anywhere by NVIDIA what the specified behavior is.
The only situation I know of where L2 gets “bypassed” is for transfers from sys mem (i.e. pinned host memory) initiated by SM (device code) activity. And I imagine that could change in the future.
Here is an example of a test:
# cat t368.cu
#include <iostream>
template <typename T>
__global__ void copy_k(T *in, T *out, size_t n){
  for (size_t i = blockIdx.x*blockDim.x+threadIdx.x; i < n; i += gridDim.x*blockDim.x)
    out[i] = in[i];
using mt = int;
int main(){
  cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, 0);
  std::cout << "Device 0: " << prop.name << std::endl;
  int l2cs = prop.l2CacheSize;
  std::cout << "L2 Cache Size: " << l2cs << std::endl;
  int nsm = prop.multiProcessorCount;
  std::cout << "Multiprocesors: " << nsm << std::endl;
  size_t s = l2cs/4;
  size_t sz = s/sizeof(mt);
  s = sz*sizeof(mt);
  std::cout << "Test Buffer Size: " << s << std::endl;
  mt *in1, *out1, *out2, *r;
  cudaMalloc(&in1,  s);
  cudaMalloc(&out1, s);
  cudaMalloc(&out2, s);
  r = new mt[sz];
  cudaMemset(in1, 1, s);
  cudaMemcpy(out1, in1, s, cudaMemcpyDeviceToDevice);
  copy_k<<<nsm,512>>>(out1, out2, sz);
  cudaMemcpy(r, out2, s, cudaMemcpyDeviceToHost);
# nvcc -arch=sm_89 -o t368 t368.cu
# ncu --cache-control none --metrics lts__t_sector_op_read_hit_rate.pct ./t368
==WARNING== Note: Running with uncontrolled GPU caches. Profiling results may be inconsistent.
==PROF== Connected to process 42154 (/root/bobc/t368)
Device 0: NVIDIA L4
L2 Cache Size: 50331648
Multiprocesors: 58
Test Buffer Size: 12582912
==PROF== Profiling "copy_k" - 0: 0%....50%....100% - 1 pass
==PROF== Disconnected from process 42154
[42154] t368@127.0.0.1
  void copy_k<int>(T1 *, T1 *, unsigned long) (58, 1, 1)x(512, 1, 1), Context 1, Stream 7, Device 0, CC 8.9
    Section: Command line profiler metrics
    Metric Name                        Metric Unit Metric Value
    lts__t_sector_op_read_hit_rate.pct           %        99.98
CUDA 12.2
Based on that, it seems to me like the D2D operation is populating the L2 cache.
