According to Programming Guide :: CUDA Toolkit Documentation, we may use malloc and free in CUDA kernels or device functions to dynamically allocate or deallocate global memory. I am wondering if cudaMemcpy can be used to copy data from a pointer returned by malloc to host storage. For clarity, suppose we have
__global__ void SOME_KERNEL(SOME_STRUCT* obj, ...)
obj->SOME_MEMBER_PTR = (TYPE_OF_MEMBER *)malloc(SOME_SIZE_OF_MEMBER);
It is my understanding that we can first copy the object of SOME_STRUCT to host using, say,
cudaMemcpy((SOME_STRUCT*) obj_host, (SOME_STRUCT*) obj_device, sizeof(SOME_STRUCT), cudaMemcpyDeviceToHost);
For clarity, I am using the modifier (SOME_STRUCT*) to emphasize the type of data. I understand that (void *) is the standard type to use for cudaMemcpy calls.
Then obj->SOME_MEMBER_PTR is a pointer on host whose address is converted to device memory in some look-up-table. Intuitively, we should be able to use the following to copy data stored in the dynamically allocated memory:
cudaMemcpy((TYPE_OF_MEMBER*)mem_host, (TYPE_OF_MEMBER*)obj_host->SOME_MEMBER_PTR, sizeof(TYPE_OF_MEMBER), cudaMemcpyDeviceToHost);
However, it seems that this approach does not apply to dynamically allocated memory. On the contrary, there is no problem in copying data from memory allocated by cudaAlloc. Could anyone confirm my finding and explain why cudaMemcpy cannot be used to copy from dynamically allocated memory?
