I’m getting error code 11: invalid argument when trying to copy from the host to the device.
The following is the code:
#include <stdlib.h>
#include <stdio.h>
#include <cuda.h>
// Image libraries
#include <IL/il.h>
#include <IL/ilu.h>
#include <IL/ilut.h>
// global variables for devIL
int imageWidth;
int imageHeight;
// global variables for CUDA code
unsigned char* devImageData;
unsigned char* devIntegralImage;
// global variable for other usages
int errorCode = 0;
void checkErrorMessage(int errorCode)
switch (errorCode){
case 0:
printf("Error Code: %d\n", errorCode);
printf("CUDA Error Code: %s\n", cudaGetErrorString(cudaGetLastError()));
printf("GPU resource allocated successfully.\n");
break;
case 1:
printf("Cannot allocate for intensity image on the gpu.\n");
exit(1);
break;
case 2:
printf("Cannot allocate for integral image on the gpu.\n");
exit(1);
break;
case 3:
printf("Cannot copy data from CPU to GPU.\n");
exit(1);
break;
// return error code:
// 1: failed to allocate for devImageData
// 2: failed to allocate for devIntegraImage
int InitAllocateGPUResources(unsigned char* devimageData, unsigned char* devintegralImage, int height, int width)
if (cudaMalloc((void**)&devimageData, sizeof(unsigned char)*width*height) != cudaSuccess)
return 1;
if (cudaMalloc((void**)&devintegralImage, sizeof(unsigned char)*width*height) != cudaSuccess)
return 2;
return 0;
void FreeGPUResources(unsigned char* devimageData, unsigned char* devintegralImage)
if (devimageData)
cudaFree(devimageData);
if (devintegralImage)
cudaFree(devintegralImage);
// return erro code:
// 3: failed to copy from CPU to GPU
int copyData_CPUToGPU(unsigned char* imagedata, unsigned char* devimageData, int height, int width)
if (cudaMemcpy(devimageData, imagedata, width*height, cudaMemcpyHostToDevice) != cudaSuccess)
return 3;
return 0;
int main(int argc, char** argv)
ILuint ImgId;
// We use the filename specified in the first argument of the command-line.
if (argc < 2) {
fprintf(stderr, "Usage : %s <file> [output]\n", argv[0]);
return 1;
// Check if the shared lib's version matches the executable's version.
if (ilGetInteger(IL_VERSION_NUM) < IL_VERSION) {
printf("DevIL version is different...exiting!\n");
return 2;
// Initialize DevIL.
ilInit();
#ifdef ILU_ENABLED
iluInit();
#endif
// Generate the main image name to use.
ilGenImages(1, &ImgId);
// Bind this image name.
ilBindImage(ImgId);
// Loads the image specified by File into the image named by ImgId.
if (!ilLoadImage(argv[1])) {
printf("Could not open file...exiting.\n");
exit(1);
// Convert to intensity map
ilConvertImage(IL_LUMINANCE, IL_UNSIGNED_BYTE);
// each pixel is represented by 1 byte
ILubyte* imageBytes = ilGetData();
imageWidth = ilGetInteger(IL_IMAGE_WIDTH);
imageHeight = ilGetInteger(IL_IMAGE_HEIGHT);
// set up GPU resources
errorCode = InitAllocateGPUResources(devImageData, devIntegralImage, imageHeight, imageWidth);
checkErrorMessage(errorCode);
unsigned char* imageData = (unsigned char*)malloc(imageWidth*imageHeight*sizeof(unsigned char));
int i;
for (i = 0; i < imageWidth*imageHeight; i++)
imageData[i] = (unsigned char)imageBytes[i];
// Copy from cpu to gpu
errorCode = copyData_CPUToGPU(imageData, devImageData, imageHeight, imageWidth);
//GenIntegralImage();
// We're done with the image, so let's delete it.
ilDeleteImages(1, &ImgId);
free(imageData);
FreeGPUResources(devImageData, devIntegralImage);
return 0;
The output is:
Error Code: 0
CUDA Error Code: no error
Error Code: 3
CUDA Error Code: invalid argument
I wrote a test program (as shown below, and cudaMemcpy returned cudaSuccess):
#include <cuda.h>
#include <stdio.h>
#include <stdlib.h>
float* device;
int main(int argc, char* argv[])
float* host = (float*)malloc(sizeof(float)*10);
if (cudaMalloc((void**)&device, 10*sizeof(float)) != cudaSuccess)
printf("Failed to allocate device memory.\n");
exit(1);
if (cudaMemcpy(device, host, sizeof(float)*10, cudaMemcpyHostToDevice)!=cudaSuccess)
printf("Failed to copy from host to device.\n");
exit(1);
return 0;
The system configuration is: Ubuntu 11.04 with CUDA 4.2; and I’m using the devIL library for image operations.
Any idea why the cudaMemcpy was not working in the program?
Thank you!
