I don’t have an exact answer, but I think we can state or demonstrate a few things.
- There is or can be significant CPU/host activity associated with a runtime API call
- The nature of
cudaMemcpy is that it is a synchronizing activity on the device side, and a blocking activity on the host side. The host CPU thread cannot proceed beyond the point of the cudaMemcpy call until the API function (i.e. the transfer) has completed.
Taking those things into account, if we could get the work issued asynchronously, we might see several performance-related benefits. In order to get to asynchronous work delivery, we will need to use pinned memory, and async-style APIs. Here is a test case:
# cat t376.cu
#include <iostream>
using T = float;
const int num_checks = 4096;
__constant__ int d_first_i_from_c_const[num_checks];
__constant__ int d_check_degrees_const[num_checks];
int main(){
T *d_prior_odds, *d_check_to_error, *d_error_to_check, *d_posterior_odds;
int *d_i_from_j, *d_first_j_from_e, *d_error_degrees;
int num_errors = 1048576;
int num_edges = num_errors;
#ifndef USE_PINNED
T *check_to_error = new T[num_edges];
int *i_from_j = new int[num_edges];
int *first_j_from_e = new int[num_errors];
int *error_degrees = new int[num_errors];
T *prior_odds = new T[num_errors];
int *first_i_from_c = new int[num_checks];
int *check_degrees = new int[num_checks];
#else
T *check_to_error, *prior_odds;
int *i_from_j, *first_j_from_e, *error_degrees, *first_i_from_c, *check_degrees;
cudaHostAlloc(&check_to_error, num_edges*sizeof(T), cudaHostAllocDefault);
cudaHostAlloc(&i_from_j, num_edges*sizeof(int), cudaHostAllocDefault);
cudaHostAlloc(&first_j_from_e, num_errors*sizeof(int), cudaHostAllocDefault);
cudaHostAlloc(&error_degrees, num_errors*sizeof(int), cudaHostAllocDefault);
cudaHostAlloc(&prior_odds, num_errors*sizeof(T), cudaHostAllocDefault);
cudaHostAlloc(&first_i_from_c, num_checks*sizeof(int), cudaHostAllocDefault);
cudaHostAlloc(&check_degrees, num_checks*sizeof(int), cudaHostAllocDefault);
#endif
// Allocate GPU memory
cudaMalloc(&d_prior_odds, num_errors * sizeof(T));
cudaMalloc(&d_check_to_error, num_edges * sizeof(T));
cudaMalloc(&d_error_to_check, num_edges * sizeof(T));
cudaMalloc(&d_i_from_j, num_edges * sizeof(int));
cudaMalloc(&d_first_j_from_e, num_errors * sizeof(int));
cudaMalloc(&d_error_degrees, num_errors * sizeof(int)); // error degrees
cudaMalloc(&d_posterior_odds, num_errors * sizeof(T));
#ifndef USE_ASYNC
cudaMemcpy(d_check_to_error, check_to_error, num_edges * sizeof(T),
cudaMemcpyHostToDevice);
cudaMemcpy(d_i_from_j, i_from_j, num_edges * sizeof(int),
cudaMemcpy(d_first_j_from_e, first_j_from_e, num_errors * sizeof(int),
cudaMemcpy(d_error_degrees, error_degrees, num_errors * sizeof(int),
cudaMemcpy(d_prior_odds, prior_odds, num_errors * sizeof(T),
cudaMemcpyToSymbol(d_first_i_from_c_const, first_i_from_c,
num_checks * sizeof(int));
cudaMemcpyToSymbol(d_check_degrees_const, check_degrees,
#else
cudaMemcpyAsync(d_check_to_error, check_to_error, num_edges * sizeof(T),
cudaMemcpyAsync(d_i_from_j, i_from_j, num_edges * sizeof(int),
cudaMemcpyAsync(d_first_j_from_e, first_j_from_e, num_errors * sizeof(int),
cudaMemcpyAsync(d_error_degrees, error_degrees, num_errors * sizeof(int),
cudaMemcpyAsync(d_prior_odds, prior_odds, num_errors * sizeof(T),
cudaMemcpyToSymbolAsync(d_first_i_from_c_const, first_i_from_c,
cudaMemcpyToSymbolAsync(d_check_degrees_const, check_degrees,
#endif
# nvcc -o t376 t376.cu
# nsys nvprof --print-gpu-trace ./t376
WARNING: t376 and any of its children processes will be profiled.
Generating '/tmp/nsys-report-1652.qdstrm'
[1/3] [========================100%] report60.nsys-rep
[2/3] [========================100%] report60.sqlite
[3/3] Executing 'cuda_gpu_trace' stats report
Start (ns) Duration (ns) CorrId GrdX GrdY GrdZ BlkX BlkY BlkZ Reg/Trd StcSMem (MB) DymSMem (MB) Bytes (MB) Throughput (MBps) SrcMemKd DstMemKd Device Ctx Strm Name
659,017,735 1,398,721 125 4.194 2,994.733 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
660,843,944 1,392,738 126 4.194 3,011.510 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
662,661,578 1,402,338 127 4.194 2,990.539 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
664,490,476 1,392,961 128 4.194 3,007.316 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
666,308,334 1,414,337 129 4.194 2,965.373 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
668,020,815 1,920 130 0.016 8,533.328 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
668,040,495 2,048 131 0.016 7,999.996 Pageable Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
Generated:
/root/bobc/report60.nsys-rep
/root/bobc/report60.sqlite
# nvcc -o t376 t376.cu -DUSE_PINNED
Generating '/tmp/nsys-report-3047.qdstrm'
[1/3] [========================100%] report61.nsys-rep
[2/3] [========================100%] report61.sqlite
634,959,942 489,504 132 4.194 8,564.769 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
635,468,070 486,368 133 4.194 8,623.489 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
635,964,230 479,809 134 4.194 8,740.930 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
636,453,127 477,696 135 4.194 8,778.678 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
636,939,527 477,857 136 4.194 8,774.484 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
637,873,928 1,920 137 0.016 8,533.328 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
637,895,080 1,920 138 0.016 8,533.328 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
Generated:
/root/bobc/report61.nsys-rep
/root/bobc/report61.sqlite
# nvcc -o t376 t376.cu -DUSE_PINNED -DUSE_ASYNC
Generating '/tmp/nsys-report-d9e9.qdstrm'
[1/3] [========================100%] report62.nsys-rep
[2/3] [========================100%] report62.sqlite
738,039,940 341,600 132 4.194 12,276.728 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
738,382,693 340,736 133 4.194 12,306.088 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
738,724,549 340,608 134 4.194 12,310.282 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
739,066,277 344,288 135 4.194 12,180.259 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
739,411,557 340,481 136 4.194 12,318.671 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
739,829,318 1,632 137 0.016 10,039.214 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
739,841,126 1,632 138 0.016 10,039.214 Pinned Device NVIDIA L4 (0) 1 7 [CUDA memcpy HtoD]
Generated:
/root/bobc/report62.nsys-rep
/root/bobc/report62.sqlite
(CUDA 12.2, L4 GPU)
The first test, with no compile switches, is roughly the case you provided. Sure enough we see that there are “large” gaps in between the actual transfer activity associated with the API calls. At the moment we don’t have many clues about those gaps.
The second test introduces pinned memory. This shortens the duration of the transfers, but also for a number of the transfers, it significantly reduces the gap from the end of one transfer to the start of the next. But the gap from the last cudaMemcpy to the first cudaMemcpyToSymbol is still quite long.
The third test introduces async calls. This means that the CPU thread no longer has to wait on a particular API call for the transfer to complete; it can “race ahead” and issue the work, perhaps allowing the CPU thread to get some of the “overhead” associated with launching these operations “out of the way”, or “amortized” during the “idle” time previously associated with waiting for a particular transfer to complete. In these case we see all gaps reduced, compared to the previous cases.
Here are the tabulated results:
| Case1 - Original |
| start |
duration |
end |
gap |
| 659,017,735 |
1,398,721 |
660,416,456 |
| 660,843,944 |
1,392,738 |
662,236,682 |
427,488 |
| 662,661,578 |
1,402,338 |
664,063,916 |
424,896 |
| 664,490,476 |
1,392,961 |
665,883,437 |
426,560 |
| 666,308,334 |
1,414,337 |
667,722,671 |
424,897 |
| 668,020,815 |
1,920 |
668,022,735 |
298,144 |
| 668,040,495 |
2,048 |
668,042,543 |
17,760 |
| Case2 - with pinned memory |
| start |
duration |
end |
gap |
| 634,959,942 |
489,504 |
635,449,446 |
| 635,468,070 |
486,368 |
635,954,438 |
18,624 |
| 635,964,230 |
479,809 |
636,444,039 |
9,792 |
| 636,453,127 |
477,696 |
636,930,823 |
9,088 |
| 636,939,527 |
477,857 |
637,417,384 |
8,704 |
| 637,873,928 |
1,920 |
637,875,848 |
456,544 |
| 637,895,080 |
1,920 |
637,897,000 |
19,232 |
| Case3 - with pinned memory and async |
| start |
duration |
end |
gap |
| 738,039,940 |
341,600 |
738,381,540 |
| 738,382,693 |
340,736 |
738,723,429 |
1,153 |
| 738,724,549 |
340,608 |
739,065,157 |
1,120 |
| 739,066,277 |
344,288 |
739,410,565 |
1,120 |
| 739,411,557 |
340,481 |
739,752,038 |
992 |
| 739,829,318 |
1,632 |
739,830,950 |
77,280 |
| 739,841,126 |
1,632 |
739,842,758 |
10,176 |
Here are some additional questions I’m not able to answer:
- Why does the transition from
cudaMemcpyAsync to cudaMemcpyToSymbolAsync still show a relative large gap compared to the other transfers, even in the 3rd test case?
- When using pinned memory, why does switching from non-async API variants to async API variants result in faster transfer rate (shorter duration)?
To go back to providing a response to the original question: It seems that there is something about pageable transfers and also something about the blocking nature of the API being used that results in increased gaps between actual transfer activity, when cudaMemcpy-style calls are issued “back to back”.
It also stands to reason that if the host CPU “matters”, then:
- a faster host CPU may help
- a heavily loaded host CPU may degrade the results
In my test case, I can state that I am the only user of this machine under test, so I believe that the host CPU is not heavily loaded by unrelated tasks. Its not a particularly fast CPU (Xeon E5-2630L v3, 1.80GHz), however. This is also a rather ancient server so I believe it is only PCIE Gen3 capable; so don’t read too much into the indicated transfer rates; I don’t view that as the focus of the original question. (The L4 GPU I’m using is a gen4 capable GPU, but the server is not.)
One of the things that is mentioned about pageable transfers is that they generally proceed by copying the data chunk-by-chunk to a pinned buffer, and then executing the transfer via potentially a sequence of transfers from the pinned buffer. I believe this general mechanism is part of the explanation for a lower transfer rate observed with pageable transfers vs. pinned transfers, but we could also speculate that the additional buffer handling process could possibly also impact latency, and therefore the “gap” between one pageable transfer and the next. This article mentions this mechanism and may also be a good resource for the general topic here.
