Hi Guys,
I am currently playing around with my Geforce GTX 560 Ti Phantom and CUDA under Visual Studio 2010 Cuda SDK 4.1 and NSight 2.1. I bought the book “Cuda By Example” and tried to run the Julia Set sample. It works, but there are problems copying the Device image data to host memory via cudaMemcpy. I tried to synchroniz threads and read the last error, but I still get “unknown error”. Furthermore, my Device driver must restart because of unknown problems. This error can be reproducted in changed a scale factor from 1.5 to 0.2. HEre some code:
This works:
__device__ int julia(int x,int y)
const float scale = 1.5f;
float jx = scale * (float)(DIM / 2 - x) / (float)(DIM/2);
float jy = scale * (float)(DIM / 2 - y) / (float)(DIM/2);
cuComplex c(-0.8f, 0.156f);
cuComplex a(jx, jy);
int i = 0;
for(i=0; i < 200; i++)
a = a*a + c;
if (a.magnitude2() > 1000)
return 0;
return 1;
This does not work (changed const float):
const float scale = 0.2f;
int i = 0;
a = a*a + c;
return 0;
return 1;
This does not make really sense. I use the current drivers. Does anyone have any idea?
Greetz TrommlBomml
