When I run the following code I get an invalid argument error at the line:
cutilSafeCall(cudaMemcpy3D(©Params2) );
Oddly, everything is fine in emulation mode.
What am I doing wrong?
Here is the code:
[codebox]const size_t nx = 541;
const size_t ny = 541;
const size_t nz = 114;
const size_t pad = 4;
dim3 dimBlock(16, 16, 1);
dim3 dimGrid(((nx-2pad)(ny-2*pad) -1)/ dimBlock.x+1, (nz-1)/ dimBlock.y+1, 1);
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc();
const cudaExtent textSize = make_cudaExtent(nx, ny, nz+2*pad);
cutilSafeCall( cudaMalloc3DArray(&d_volumeArray, &channelDesc, textSize) );
float* d_res;
cutilSafeCall(cudaMalloc((void**)&d_res, (nz+2pad)nxnysizeof(float)));
cutilSafeCall(cudaMemset(d_res, 0, nxny(nz+2*pad)*sizeof(float)));
setValKernel<<< dimGrid, dimBlock, 0 >>>(nx, ny, nz, d_res);
cutilSafeCall(cudaThreadSynchronize());
cudaMemcpy3DParms copyParams2 = {0};
copyParams2.srcPtr.ptr = d_res;
copyParams2.srcPtr.pitch = nx*sizeof(float);
copyParams2.srcPtr.xsize = nx;
copyParams2.srcPtr.ysize = ny;
copyParams2.dstArray = d_volumeArray;
copyParams2.extent = textSize;
copyParams2.kind = cudaMemcpyDeviceToDevice;
cutilSafeCall(cudaMemcpy3D(©Params2) );[/codebox]
here are my device properties:
Clock rate=1296000
Device overlap=1
Major=1
Minor=3
Max grid size=65535 65535 1
maxThreadsDim=512 512 64
maxThreadsPerBlock=512
memPitch=262144
multiProcessorCount=30
name=Tesla C1060
regsPerBlock=16384
sharedMemPerBlock=16384
textureAlignment=256
totalConstMem=65536
totalGlobalMem=4294705152
warpSize=32
Thanks for the help.
sd.
