To verify the guidance on CUDA streams in the CUDA Programming Guide, I wrote up and tested a relatively simple program whose outputs seems to go against what the Guide says:
Kernel launches and host ↔ device memory copies that do not specify any stream parameter, or equivalently that set the stream parameter to zero, are issued to the default stream. They are therefore executed in order.
From the above, I assumed that if my program issues kernel launches and memory copies using cudaMemcpyAsync() to the default stream, then it will not be any faster than just using cudaMemcpy.
My program tests this assumption as follows (pseudocode below, full code at the very bottom of my post):
pinned_memory = // from cudaMallocHost()
num_iter = // from command line
// time_synchronous()
for num_iter
dummy_compute_kernel()
cudaMemcpy()
cudaMemcpy()
end
// time_asynchronous()
for num_iter
cudaMemcpyAsync()
cudaMemcpyAsync()
end
// time_async_then_sync()
for num_iter
cudaMemcpyAsync()
cudaMemcpy()
end
I do not specify any stream parameter, so I would expect time_synchronous(), time_asynchronous() and time_async_then_sync() to all have similar execution times but this is not the case. Instead, the execution times ranked from lowest to highest were (on a GTX 2070):
time_asynchronous()time_async_then_sync()time_synchronous().
Why is cudaMemcpyAsync() faster than cudaMemcpy() when I am only using the default stream 0?
As an important follow up question, if there is a cudaMemcpy(..., cudaMemcpyDefault) call in some code, will it serialise any further cudaMemcpyAsync(...,cudaMemcpyDefault) calls?
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include "cstdio"
#include "cstdlib"
#include "cstring"
#define ELEMS (1 << 20)
#define THREADS_PER_BLOCK 256
#define CHECK_CUDA_ERROR(ans) { cuda_assert( ans, __FILE__, __LINE__ ); }
inline
void cuda_assert
cudaError_t error,
const char* file,
int line
if (error != cudaSuccess)
fprintf(stderr, "CUDA error: %s, %s, %d\n", cudaGetErrorString(error), file, line);
exit(error);
void* malloc_device(size_t bytes);
void* malloc_pinned(size_t bytes);
cudaError_t cu_copy
void* dst,
void* src,
size_t bytes
cudaError_t cu_copy_async
void* dst,
void* src,
size_t bytes
__global__
void dummy_compute_kernel(double* d_array);
void time_synchronous
double* d_array,
double* h_array,
int num_iter,
int num_blocks,
size_t bytes
void time_asynchronous
double* d_array,
double* h_array,
int num_iter,
int num_blocks,
size_t bytes
void time_async_then_sync
double* d_array,
double* h_array,
int num_iter,
int num_blocks,
size_t bytes
int main
int argc,
char** argv
if (argc < 2)
fprintf(stderr, "\nPlease enter the number of iterations as a command line argument.\n");
exit(-1);
const int num_iter = strtol(argv[1], nullptr, 10);
const int num_blocks = ELEMS / THREADS_PER_BLOCK;
const size_t bytes = sizeof(double) * ELEMS;
double* h_array = (double*)malloc_pinned(bytes);
double* d_array = (double*)malloc_device(bytes);
CHECK_CUDA_ERROR( cu_copy(d_array, h_array, bytes) );
time_synchronous
d_array,
h_array,
num_iter,
num_blocks,
bytes
time_asynchronous
d_array,
h_array,
num_iter,
num_blocks,
bytes
d_array,
h_array,
num_iter,
num_blocks,
bytes
CHECK_CUDA_ERROR( cudaFreeHost(h_array) );
CHECK_CUDA_ERROR( cudaFree(d_array) );
return 0;
void* ptr;
CHECK_CUDA_ERROR( cudaMalloc(&ptr, bytes) );
return ptr;
void* ptr;
CHECK_CUDA_ERROR( cudaMallocHost(&ptr, bytes) );
memset(ptr, 0, bytes);
return ptr;
cudaError_t cu_copy
void* dst,
void* src,
size_t bytes
return cudaMemcpy(dst, src, bytes, cudaMemcpyDefault);
void* dst,
void* src,
size_t bytes
return cudaMemcpyAsync(dst, src, bytes, cudaMemcpyDefault);
__global__
const int idx = blockIdx.x * blockDim.x + threadIdx.x;
d_array[idx] += cos( (double)idx );
double* d_array,
double* h_array,
int num_iter,
int num_blocks,
size_t bytes
cudaEvent_t cuda_begin, cuda_end;
CHECK_CUDA_ERROR( cudaEventCreate(&cuda_begin) );
CHECK_CUDA_ERROR( cudaEventCreate(&cuda_end) );
cudaEventRecord(cuda_begin);
for (int i = 0; i < num_iter; i++)
dummy_compute_kernel<<<num_blocks, THREADS_PER_BLOCK>>>(d_array);
CHECK_CUDA_ERROR( cu_copy(h_array, d_array, bytes) );
CHECK_CUDA_ERROR( cudaEventRecord(cuda_end) );
CHECK_CUDA_ERROR( cudaEventSynchronize(cuda_end) );
float cuda_time = 0;
CHECK_CUDA_ERROR( cudaEventElapsedTime(&cuda_time, cuda_begin, cuda_end) );
printf("\nSynchronous runtime: %f ms\n", cuda_time);
double* d_array,
double* h_array,
int num_iter,
int num_blocks,
size_t bytes
CHECK_CUDA_ERROR( cu_copy_async(h_array, d_array, bytes) );
printf("\nAsynchronous runtime: %f ms\n", cuda_time);
double* d_array,
double* h_array,
int num_iter,
int num_blocks,
size_t bytes
CHECK_CUDA_ERROR( cu_copy (h_array, d_array, bytes) );
printf("\nAsynchronous then synchronous runtime: %f ms\n", cuda_time);
