I am trying to move data structures from host to constant memory on a Tesla C1060 (compute 1.3). With the following function in mem.cu:
//mem.cu
#include "kernel.cuh"
int InitDCMem(SimuationStruct *sim)
SimParamGPU h_simparam;
h_simparam.na = sim->det.na;
h_simparam.nz = sim->det.nz;
h_simparam.nr = sim->det.nr;
cudaMemcpyToSymbol(d_simparam, &h_simparam, sizeof(SimParamGPU));
The data structure (in a header file):
//kernel.cuh
typedef struct __align__(16)
int na;
int nz;
int nr;
} SimParamGPU;
__constant__ SimParamGPU d_simparam;
The problem is that it seems the values are not being copied to the constant memory in the GPU.
Do I need to re-declare constant on \mem.cu. Which will only work if I enable “Generate Relocatable Device Code” option (-rdc=true).
Should I use ‘extern’ or ‘extern “C”’ in the kernel.cu source? (tried with errors).
There are no errors, the values are always set to 0 even though on the host side they are set properly.
