I am Using Ubuntu Karmic (9.10) which comes with GCC 4.4
I am trying to compile cuda sdk 2.3 and I am having these messages when I try to run make on the SDK, After I add
NVCCFLAGS += --compiler-options -fno-inline
To common/common.mk
make[1]: Entering directory `/home/odin/software/cudasdk/2.3/C/common'
make[1]: Leaving directory `/home/odin/software/cudasdk/2.3/C/common'
make -C src/MonteCarlo/
make[1]: Entering directory `/home/odin/software/cudasdk/2.3/C/src/MonteCarlo'
/usr/include/string.h:43: error: inline function ‘void* memcpy(void*, const void*, size_t)’ cannot be declared weak
/usr/include/string.h:64: error: inline function ‘void* memset(void*, int, size_t)’ cannot be declared weak
/usr/include/bits/string3.h:49: error: inline function ‘void* memcpy(void*, const void*, size_t)’ cannot be declared weak
/usr/include/bits/string3.h:78: error: inline function ‘void* memset(void*, int, size_t)’ cannot be declared weak
/usr/local/cuda/bin/../include/common_functions.h:59: error: inline function ‘void* memset(void*, int, size_t)’ cannot be declared weak
/usr/local/cuda/bin/../include/common_functions.h:62: error: inline function ‘void* memcpy(void*, const void*, size_t)’ cannot be declared weak
make[1]: *** [obj/release/MonteCarlo_SM10.cu_sm_10.o] Error 255
make[1]: Leaving directory `/home/odin/software/cudasdk/2.3/C/src/MonteCarlo'
make: *** [src/MonteCarlo/Makefile.ph_build] Error 2
Does anyone know how to use GCC 4.3 instead of GCC 4.4 in Ubuntu? I think that you should replace some symbolic links but I don’t know where.
LTram
September 14, 2009, 4:44am
2
You could uninstall gcc 4.4 and install 4.3. It doesn’t take that long to do with synaptic.
Zoide
November 7, 2009, 8:45pm
4
You can open Synaptic from System → Administration → Synaptic Package Manager
Search for gcc and you’ll see an entry for gcc-4.3. Right click on it and select “Mark for instalation”. Click on the Apply button and it will be installed.
Next you should go to /usr/bin and remake the softlink to gcc with version 4.3:
sudo rm gcc
sudo ln -s gcc-4.3 gcc
Let me know if that works ;)
QD4_33
November 10, 2009, 3:02pm
5
Hello everybody!
I managed to work with Ubuntu 9.10 (AMD64). As you did, I installed g+±4.3 and gcc-4.3 packages and created new symlinks (I think, that is not necessary. Editing CC and CXX variables in /SDKPATH/C/common/commom.mk should be sufficient).
Owing to the fact, that I used a fresh installation, some of you may have some additional problems.
You have to install Glut (I installed the developement-packages, too), libXi-dev and libXmu-dev to get a successful sdk-compilation.
Furthermore, I got errors like …
… after compiling.
To avoid this, add the line
to /etc/ld.so.conf and run sudo ldconfig
Hi all,
I tried changing the common.mk but no luck. Then I decided to properly use the update-alternatives and it worked!
The sequence of commands is:
[codebox]sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.4 44 --slave /usr/bin/g++ g++ /usr/bin/g+±4.4 --slave /usr/bin/gcov gcov /usr/bin/gcov-4.4
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.3 43 --slave /usr/bin/g++ g++ /usr/bin/g+±4.3 --slave /usr/bin/gcov gcov /usr/bin/gcov-4.3[/codebox]
Note that gcc 4.4 still has higher priority when in “auto” mode. You can then check the config by typing:
[codebox]sudo update-alternatives --display gcc[/codebox]
and swap between versions with
[codebox]sudo update-alternatives --config gcc[/codebox]
Francesco
Hello everybody!
… after compiling.
omht
December 10, 2009, 2:15pm
7
Here’s a blog post that explains how to do it in some detail:
[url=“http://moelhave.dk/2009/12/nvidia-cuda-on-ubuntu-karmic-koala/ ”]http://moelhave.dk/2009/12/nvidia-cuda-on-...u-karmic-koala/[/url]
You don’t have to run update-alternatives or in other ways “hide” your gcc 4.4 from the CUDA system.
