I have a strange problem about this function.I use it in my code after the kernel.But when I debug the code step by step ,it often exit automatically at cudaThreadSynchronize().And the output window shows :cudaerror_enum occurs in memory 0x00125750.
[codebox]BemCal<<<grid,block>>>(d_obs,d_src,d_preal,d_pimag,njgroup);
//copy device result to host
cudaThreadSynchronize();
cudaGetLastError();[/codebox]
Who knows the reason?
mayank
October 5, 2009, 1:23am
2
You can try and use checkCUDAError() function. You could use it after the kernel call and see whether the kernel is properly executed or not.
