I was able to find deviceQuery under usr/local/cuda/extras/demo_suite
I am also running into the same error and I can’t figure out the solution. Here is my output to deviceQuery:
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 8 CUDA Capable device(s)
Device 0: “GeForce RTX 2080 Ti”
CUDA Driver Version / Runtime Version 11.0 / 10.1
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 11019 MBytes (11554717696 bytes)
(68) Multiprocessors, ( 64) CUDA Cores/MP: 4352 CUDA Cores
GPU Max Clock rate: 1545 MHz (1.54 GHz)
Memory Clock rate: 7000 Mhz
Memory Bus Width: 352-bit
L2 Cache Size: 5767168 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 3 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 26 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 27 / 0
Compute Mode:
Device 2: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 61 / 0
Compute Mode:
Device 3: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 62 / 0
Compute Mode:
Device 4: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 136 / 0
Compute Mode:
Device 5: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 137 / 0
Compute Mode:
Device 6: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 177 / 0
Compute Mode:
Device 7: “GeForce RTX 2080 Ti”
Warp size: 32
Device PCI Domain ID / Bus ID / location ID: 0 / 178 / 0
Compute Mode:
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU6) : No
Peer access from GeForce RTX 2080 Ti (GPU0) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU6) : No
Peer access from GeForce RTX 2080 Ti (GPU1) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU6) : No
Peer access from GeForce RTX 2080 Ti (GPU2) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU6) : No
Peer access from GeForce RTX 2080 Ti (GPU3) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU6) : No
Peer access from GeForce RTX 2080 Ti (GPU4) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU6) : No
Peer access from GeForce RTX 2080 Ti (GPU5) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU6) → GeForce RTX 2080 Ti (GPU7) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU0) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU1) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU2) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU3) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU4) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU5) : No
Peer access from GeForce RTX 2080 Ti (GPU7) → GeForce RTX 2080 Ti (GPU6) : No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.0, CUDA Runtime Version = 10.1, NumDevs = 8, Device0 = GeForce RTX 2080 Ti, Device1 = GeForce RTX 2080 Ti, Device2 = GeForce RTX 2080 Ti, Device3 = GeForce RTX 2080 Ti, Device4 = GeForce RTX 2080 Ti, Device5 = GeForce RTX 2080 Ti, Device6 = GeForce RTX 2080 Ti, Device7 = GeForce RTX 2080 Ti
Result = PASS
