cuDNN8 regression in algorithm selection heuristics
Hi, I think I’m seeing a regression in cuDNN that’s caused by convolution algorithm selection heuristics.
Background:
  1. I received report of perf regression (on V100) comparing cuda11+cudnn8 vs cuda10+cudnn7
  2. I can reproduce the regression on a GTX1080Ti comparing cuda10.2+cudnn8.0.2 vs cuda10.2+cudnn7.6.5. cudnn8.0.2 is 5%~10% slower.
  3. Our TensorFlow job requires variable-sized input, so it uses TF_CUDNN_USE_AUTOTUNE=0 (because autotune would be slow). If we change the job to use fixed-size input and enable autotune, the regression disappeared.
Therefore I think the change in algorithm selection heuristics causes the perf regression.
I managed to take a few layers from the model that suffers the most from the regression, and make a repro script below.
The script is tested on GTX1080Ti with TensorFlow2.3 (built with v1 compat mode), pip install tensorpack, cuda10.2, and cudnn7.6.5 vs cudnn8.0.2.
The results are following:
cudnn7.6.5, TF_CUDNN_USE_AUTOTUNE=0: 30.2it/s
cudnn7.6.5, TF_CUDNN_USE_AUTOTUNE=1: 41.7it/s
cudnn8.0.2, TF_CUDNN_USE_AUTOTUNE=0: 26.9it/s
cudnn8.0.2, TF_CUDNN_USE_AUTOTUNE=1: 39.4it/s
The results show that: (1) the algorithm selection heuristics are much worse than optimal (2) the algorithm selection heuristics has a 10% regression in cudnn8.
Note that tensorflow changes from using cudnnGetConvolutionForwardAlgorithm to cudnnGetConvolutionForwardAlgorithm_v7 in cudnn8 because the old API was deleted. So the regression perhaps is between these two APIs, but not between v7 and v8. But I have not verified this.
import tensorflow.compat.v1 as tf
tf.disable_eager_execution()
import numpy as np
import time
from tensorpack.models import Conv2D, MaxPooling
from tensorpack import argscope
def fpn_model(features):
    assert len(features) == 4, features
    num_channel = 256
    def upsample2x(name, x):
        resize = tf.image.resize_images
        with tf.name_scope(name):
            shp2d = tf.shape(x)[2:]
            x = tf.transpose(x, [0, 2, 3, 1])
            x = resize(x, shp2d * 2, 'nearest')
            x = tf.transpose(x, [0, 3, 1, 2])
            return x
    with argscope(Conv2D, data_format='channels_first', activation=tf.identity, use_bias=True):
        lat_2345 = [Conv2D('lateral_1x1_c{}'.format(i + 2), c, num_channel, 1)
                    for i, c in enumerate(features)]
        lat_sum_5432 = []
        for idx, lat in enumerate(lat_2345[::-1]):
            if idx == 0:
                lat_sum_5432.append(lat)
            else:
                lat = lat + upsample2x('upsample_lat{}'.format(6 - idx), lat_sum_5432[-1])
        p2345 = [Conv2D('posthoc_3x3_p{}'.format(i + 2), c, num_channel, 3)
                 for i, c in enumerate(lat_sum_5432[::-1])]
        p6 = MaxPooling('maxpool_p6', p2345[-1], pool_size=1, strides=2, data_format='channels_first', padding='VALID')
        return p2345 + [p6]
def get_data(name, shape):
    var = tf.get_variable(name, shape=shape)
    shape[2] = None
    shape[3] = None
    # use this trick to clear static shapes and prevent some optimization
    return tf.placeholder_with_default(var, shape=shape)
def model():
    x1 = get_data('x1', [1, 256, 200, 304])
    x2 = get_data('x2', [1, 512, 100, 152])
    x3 = get_data('x3', [1, 1024, 50, 76])
    x4 = get_data('x4', [1, 2048, 25, 38])
    c2345 = [x1, x2, x3, x4]
    out = fpn_model( c2345)
    loss = tf.add_n([tf.reduce_mean(x) for x in out])
    train_op = tf.train.GradientDescentOptimizer(0.01).minimize(loss,
            var_list=tf.trainable_variables())
    return train_op
def benchmark(op, nr_iter=300, nr_warmup=10):
    for k in range(nr_warmup):
        op.run()
    start = time.perf_counter()
    for k in range(nr_iter):
        op.run()
    end = time.perf_counter()
    itr_per_sec = nr_iter * 1. / (end - start)
    return itr_per_sec
with tf.device('/gpu:0'):
    train_op = model()
config = tf.ConfigProto()
config.allow_soft_placement = True
sess = tf.Session(config=config)
with sess.as_default():
    sess.run(tf.global_variables_initializer())
    speed = benchmark(train_op)
    print(speed)
I also parsed the debug output of cuDNN API call, and these are the convolution operators where v7 and v8 disagree on algorithms:
v7 cudnnConvolutionForward
OrderedDict([('xDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('xDesc.dimA', '[1,256,25,38]'),
             ('xDesc.strideA', '[243200,950,38,1]'),
             ('wDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('wDesc.dimA', '[256,256,3,3]'),
             ('wDesc.format', 'CUDNN_TENSOR_NCHW (0)'),
             ('convDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('convDesc.padA', '[1,1]'),
             ('convDesc.strideA', '[1,1]'),
             ('convDesc.dilationA', '[1,1]'),
             ('convDesc.groupCount', '1'),
             ('algo', 'CUDNN_CONVOLUTION_FWD_ALGO_WINOGRAD (6)'),
             ('yDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('yDesc.dimA', '[1,256,25,38]'),
             ('yDesc.strideA', '[243200,950,38,1]')])
v8 cudnnConvolutionForward
             ('algo', 'CUDNN_CONVOLUTION_FWD_ALGO_GEMM (2)'),
v7 cudnnConvolutionBackwardFilter
             ('xDesc.dimA', '[1,256,50,76]'),
             ('xDesc.strideA', '[972800,3800,76,1]'),
             ('dyDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('dyDesc.dimA', '[1,256,50,76]'),
             ('dyDesc.strideA', '[972800,3800,76,1]'),
             ('algo', 'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_0 (0)'),
             ('dwDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('dwDesc.dimA', '[256,256,3,3]'),
             ('dwDesc.format', 'CUDNN_TENSOR_NCHW (0)')])
v8 cudnnConvolutionBackwardFilter
             ('algo',
              'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_WINOGRAD_NONFUSED (5)'),
             ('dyDesc.dimA', '[1,256,25,38]'),
             ('dyDesc.strideA', '[243200,950,38,1]'),
             ('algo',
v7 cudnnConvolutionBackwardData
OrderedDict([('wDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('wDesc.dimA', '[256,256,1,1]'),
             ('dyDesc.dimA', '[1,256,200,304]'),
             ('dyDesc.strideA', '[15564800,60800,304,1]'),
             ('convDesc.padA', '[0,0]'),
             ('algo', 'CUDNN_CONVOLUTION_BWD_DATA_ALGO_1 (1)'),
             ('dxDesc.dataType', 'CUDNN_DATA_FLOAT (0)'),
             ('dxDesc.dimA', '[1,256,200,304]'),
             ('dxDesc.strideA', '[15564800,60800,304,1]')])
v8 cudnnConvolutionBackwardData
             ('algo', 'CUDNN_CONVOLUTION_BWD_DATA_ALGO_0 (0)'),
             ('xDesc.dimA', '[1,256,200,304]'),
             ('xDesc.strideA', '[15564800,60800,304,1]'),
             ('algo', 'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_3 (3)'),
             ('dwDesc.dimA', '[256,256,1,1]'),
             ('xDesc.dimA', '[1,512,100,152]'),
             ('xDesc.strideA', '[7782400,15200,152,1]'),
             ('dyDesc.dimA', '[1,256,100,152]'),
             ('dyDesc.strideA', '[3891200,15200,152,1]'),
             ('dwDesc.dimA', '[256,512,1,1]'),
             ('xDesc.dimA', '[1,1024,50,76]'),
             ('xDesc.strideA', '[3891200,3800,76,1]'),
             ('algo', 'CUDNN_CONVOLUTION_BWD_FILTER_ALGO_1 (1)'),
             ('dwDesc.dimA', '[256,1024,1,1]'),
             ('xDesc.dimA', '[1,2048,25,38]'),
             ('xDesc.strideA', '[1945600,950,38,1]'),
             ('dwDesc.dimA', '[256,2048,1,1]'),
Hi @ppwwyyxxc,
Please allow me some time to check on this.
Hi @ppwwyyxxc,
Request you to provide API logs for the entire model run.
Thanks for taking a look! The logs for the following three settings are attached:
logs.tar.gz (621.8 KB)
I modified the script to use nr_iter=10 to limit the log size. This change does not affect benchmark results.
Thank you. We are taking a lot at this and will get back to you shortly.
Hi, is there an update on this issue? Thanks a lot for taking a look.
