Dear all,
I’ve just installed cuDNNv6.0 and trying to compile/run example files. I was able to execute RNN example smoothly.
However, for cudnn_samples_v6/mnistCUDNN example, I got some compile errors from make (see details below).
It appears I have something wrong with cuda_runtime_api.h enum declarations. Q: any suggestions?
compile error details
nvcc warning : The ‘compute_20’, ‘sm_20’, and ‘sm_21’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
/usr/local/cuda/bin/nvcc -ccbin g++ -I/usr/local/cuda/include -IFreeImage/include -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_53,code=compute_53 -o fp16_dev.o -c fp16_dev.cu
g++ -I/usr/local/cuda/include -IFreeImage/include -o fp16_emu.o -c fp16_emu.cpp
g++ -I/usr/local/cuda/include -IFreeImage/include -o mnistCUDNN.o -c mnistCUDNN.cpp
In file included from /usr/local/cuda/include/channel_descriptor.h:62:0,
from /usr/local/cuda/include/cuda_runtime.h:90,
from /usr/include/cudnn.h:64,
from mnistCUDNN.cpp:30:
/usr/local/cuda/include/cuda_runtime_api.h:1628:101: error: use of enum ‘cudaDeviceP2PAttr’ without previous declaration
extern host cudart_builtin cudaError_t CUDARTAPI cudaDeviceGetP2PAttribute(int *value, enum cudaDeviceP2PAttr attr, int srcDevice, int dstDevice);
/usr/local/cuda/include/cuda_runtime_api.h:5382:92: error: use of enum ‘cudaMemoryAdvise’ without previous declaration
extern host cudaError_t CUDARTAPI cudaMemAdvise(const void *devPtr, size_t count, enum cudaMemoryAdvise advice, int device);
/usr/local/cuda/include/cuda_runtime_api.h:5438:98: error: use of enum ‘cudaMemRangeAttribute’ without previous declaration
extern host cudaError_t CUDARTAPI cudaMemRangeGetAttribute(void *data, size_t dataSize, enum cudaMemRangeAttribute attribute, const void *devPtr, size_
/usr/local/cuda/include/cuda_runtime_api.h:5474:102: error: use of enum ‘cudaMemRangeAttribute’ without previous declaration
extern host cudaError_t CUDARTAPI cudaMemRangeGetAttributes(void **data, size_t *dataSizes, enum cudaMemRangeAttribute *attributes, size_t numAttribute
Makefile:200: recipe for target ‘mnistCUDNN.o’ failed
make: *** [mnistCUDNN.o] Error 1
