Hi all, I’m new to CUDA programming.
As first exercise I’m trying to port some code (not mine…) which has a fft convolution part. In principle it should be easy, as it is written using fftw3. AFAIK fftw3 <-> cufft implementations are quite similar (from the interface point of view).
I have only a quiestion on cufftPlan1d functions which gets a “BATCH” number as last argument… What is exactly this number?
I have another question regarding the kernel invocation… how can I choose N, T in <<<N, T>>> in an optimal way? Or… how can I set them to be chosen at runtime so that different GPUs (with different capabilities) have optimal settings?
Sorry if these questions look quite trivial to you ^__^.
d
