Hi !
I wanted to ship a binary of my application which uses cuFFT. I have a few tens of thousands of lines of code which compile to about 2Mo. I was somewhat surprised when I discovered that my version of CuFFT64_10.dll is over 140Mo in size !
I’m guessing that’s something I have to live with, correct ?
If I were to compile using a static library (thereby not on Windows), then I’m assuming that most of the symbols would remain unused and not linked into the executable, is that correct ?. Any idea if I may gain a significant amount of weight (assuming for example that I use no callbacks and only 1D FFTs) ?
Thanks !
