Function cufftExecR2C has this in its description:
cufftExecR2C() (cufftExecD2Z()) executes a single-precision (double-precision) real-to-complex, implicitly forward, cuFFT transform plan. cuFFT uses as input data the GPU memory pointed to by the idata parameter. This function stores the nonredundant Fourier coefficients in the odata array.
As a result, the output only contains the first half of the result. For example, the output is this:
15 + 0
-2.5 + 3.44095
-2.5 + 0.812299
0 + 0 // second half is zero-filled
0 + 0 // it's symmetric with the first half, is there any parameter to fill it too?
Expected:
(+1.500e+01,+0.000e+00)
(-2.500e+00,+3.441e+00)
(-2.500e+00,+8.123e-01)
(-2.500e+00,-8.123e-01)
(-2.500e+00,-3.441e+00)
We can write an extra kernel to fill the second half of the output, but that’s an extra step. Is there any built-in method in cuFFT to fill the whole array instead of just the first half?
