cuFFT handle in C Struct
Please Help,
I have been going around with this issue for a couple of days and can’t seem to understand why it is not working. I have a C-code struct which has a cufftHandle variable (fftHandle) and is defined in a separate C file (defines.cu). However when I try to access the fftHandle variable from a different C file it doesn’t work. There are no compile errors, but it doesn’t seem to work - i.e., after calling functions declared in my header file (defines.cuh) from another C file (other.cu) the values returned from GPU are always zero.
Can anyone offer any help?
The code follows:
defines.cuh
// includes for cuffs here
typedef struct{
  cufftHandle fftHandle;
} myFFT;
void initFFT(myFFT *fft, const int n);
void execFFT(myFFT *fft, cuComplex *d_in, cuComplex *d_out);
defines.cu
#include "defines.cuh"
void initFFT(myFFT *fft, const int n){
  cufftPlan1d(&cufft->fftHandle, n, CUFFT_C2C, 1);
void execFFT(myFFT *fft, cuComplex *d_in, cuComplex *d_out){
  cufftExecC2C(fft->fftHandle, d_in, d_out, CUFFT_FORWARD);
other file: other.cu
myFFT myfft;
const int n = 10;
cuComplex *d_in;
cuComplex *d_out;
cudaMalloc((void**)&d_in, n*sizeof(cuComplex));
cudaMalloc((void**)&d_out, n*sizeof(cuComplex));
// HOST
cuComplex *h_in;
cuComplex *h_out;
h_in = (cuComplex*)malloc(n*sizeof(cuComplex));
h_out = (cuComplex*)malloc(n*sizeof(cuComplex));
// load some data into HOST array h_in, e.g. random numbers [1-10]
// copy to DEVICE
cudaMemcpy(d_in, h_in, n*sizeof(cuComplex), cudaMemcpyHostToDevice);
// create a plan
initFFT(&myfft, n);
// execute
execFFT(&myfft, d_in, d_out);
// get result from DEVICE
cudaMemcpy(h_out, d_out, n*sizeof(cuComplex) cudaMemcpyDeviceToHost);
// at this stage h_out always has all zeros
I doubt this is the code you are actually using (especially initFFT). So its easier for others if you do a better job of representing what you are doing.
I would also recommend doing proper error checking throughout, both CUFFT and CUDA runtime API calls.
Thank you for the response.
The code I showed in my post is not complete, I wanted to just show the important part(s). However, the initFFT function is the same. It’s suppose to be a simple FFT FORWARD code that calls CUFFT operations “under the hood” - but the driver.cu output is always a set of zeros.
I guess the main problem I am having is how to create a single struct with a cufftHandle defined within that can be used by any number of .cu files. Am I defining the struct for this type of situation incorrectly? I am not a C expert.
I have included the complete code below:
in myfft.cuh:
// Standard C
#include <stdio.h>
#include <stdlib.h>
// CUDA
#include <cuda.h>
#include <cufft.h>
#include <cuComplex.h>
// struct that I want to hold CUFFT handle within
typedef struct{
} myFFT;
// functions I want to operate on defined struct such that the
// underlying CUFFT library can be employed
in myfft.cu:
#include "myfft.cuh"
in driver.cu
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char **argv){
int i = 0;
// defined structure with cufftHandle in it
myFFT myfft;
// size of array
const int n = 100;
// DEVICE memory
cuComplex *d_in;
cuComplex *d_out;
// HOST memory
cuComplex *h_in;
cuComplex *h_out;
// load some data into HOST array h_in:
for(i = 0; i < n; ++i){
  h_in[i].x = i + 1;
  h_in[i].y = 1;
// copy to DEVICE
// create a plan
initFFT(&myfft, n);
// execute
// at this stage h_out always has all zeros - only checking REALS
  printf("%f\n", h_out[i].x);
free(h_in);
free(h_out);
cudaFree(d_in);
cudaFree(d_out);
return 0;
This cannot possibly work, it should not even compile:
This also won’t compile:
So if you claim to be compiling and running this code, I don’t believe you.
Here’s an example that seems to work for me:
$ cat defines.cuh
#include <cufft.h>
typedef struct{
} myFFT;
$ cat defines.cu
  cufftPlan1d(&fft->fftHandle, n, CUFFT_C2C, 1);
$ cat other.cu
#include <iostream>
int main(){
myFFT myfft;
const int n = 10;
cuComplex *d_in;
cuComplex *d_out;
// HOST
cuComplex *h_in;
cuComplex *h_out;
for (int i = 0; i < n; i++){
  h_in[i].x = 1.0f;
  h_in[i].y = i;}
// copy to DEVICE
// create a plan
initFFT(&myfft, n);
// execute
cudaMemcpy(h_out, d_out, n*sizeof(cuComplex), cudaMemcpyDeviceToHost);
for (int i = 0; i < 10; i++)
  std::cout << h_out[i].x << std::endl;
$ nvcc -o test other.cu defines.cu -lcufft
$ ./test
10
-15.3884
-6.88191
-3.63271
-1.6246
0
1.6246
3.63271
6.88191
15.3884
Okay, sorry. The code I posted had typos when I was writing from memory - I didn’t have the code in front of me.
So there is nothing inherently wrong with the way I am using struct and cufftHandle with functions (as per your code)? Interesting, given your code works there must be something else I am doing incorrectly.
Thank you for your help.
