cufftExecC2C and cudaMemcpyAsync Doing the FFT without 100% CPU usage
Hi everyone,
I would like to perform 1D C2C FFTs without causing the CPU utilization to go to 100%. I have seen many forum posts about using cudaMemcpyAsync and to look at the asyncAPI example. However, I have tried the recommendations that all of these posts talk about. None of them work. And yes, I am using pinned memory via cudaMallocHost().
Would someone be willing to please post some code that does the following and does not eat up 100% CPU:
  1. Copy data from host memory (CPU) to GPU
  2. FFT the data via the GPU
  3. Copy result back to the host memory (CPU)
From all the postings I have seen, something like the following should work, but doesnt:
cudaEventCreate(evt);
cudaAsyncMemcpy(device, host, size, 0);
cufftExecC2c(device, plan, etc..)
cudaAsyncMemcpy(host, device, size, 0);
while(cudaQueryEvent(evt) == cudaErrorNotRead)
   usleep(1000);
I have tried several variations of this covered in the many posts on the topic. I have tried appending each step (of the 3 I mentioned above) with cudaThreadSync() stuff. I have also tried to wrap each step with sleeps and had no luck… see below:
   usleep(1000);
cudaEventCreate(evt2);
while(cudaQueryEvent(evt2) == cudaErrorNotRead)
   usleep(1000);
cudaEventCreate(evt3)
while(cudaQueryEvent(evt3) == cudaErrorNotRead)
   usleep(1000);
Please help!
The 100% CPU utilization is triggered by the copy back ( CPU goes in a spin wait).
You can avoid it delaying the call to the copy back.
copy(device,host)
FFTonGPU
do_something_else_on_CPU(or just sleep)
copy(host,device)
Why does the CPU have to go into a spin wait? Why cant I asynchronously copy the data back to the CPU so my thread yeilds to other processes in the system?
Additionally, this answer does not solve my problem. When I use the pseudo code mentioned above, I dont see the correct FFT results in the host memory (regardless of the fact it might exhibit 100% utilization). I only get the correct answer when I do synchronous memcps and wrap the FFT in a safe call macro. See code following:
CUDA_SAFE_CALL(cudaMemcpy(deviceMem, &(hostMem[idx]), memSizeDevice, cudaMemcpyHostToDevice));
CUFFT_SAFE_CALL(cufftExecC2C(plan, (cufftComplex *)deviceMem, (cufftComplex *)deviceMem, CUFFT_FORWARD));
CUDA_SAFE_CALL(cudaMemcpy(&(hostMem[idx]), deviceMem, memSizeDevice, cudaMemcpyDeviceToHost));
It goes in spin wait to reduce latency.
CUDA_SAFE_CALL macros are completely useless in release mode, you have a bug somewhere else. You should see the correct result in host memory after the cudamemcpy.
How do I know I am in release mode?
Here is the code I am running. You will see it doesnt give the correct results. What is wrong with it?
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cufft.h>
#include <cutil.h>
// includes, special
#include <ctype.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
// Complex data type
typedef float2 Complex;
int createArray(Complex *arrayPtr, int arrayLength);
int main(int argc, char** argv)
  int fftSize = 1*1024;
  int memSizeHost = 512*(1024*1024);
  Complex* hostMem = 0;
  Complex* deviceMem = 0;
  int batchSize = 1;
 CUT_DEVICE_INIT(1, "");
 // Allocate memory on GPU and RAM
  memSizeHost = (memSizeHost / (fftSize*sizeof(Complex))) * (fftSize*sizeof(Complex));
  int memSizeDevice = sizeof(Complex) * fftSize * batchSize;
 // Allocate memory in RAM
  CUDA_SAFE_CALL(cudaMallocHost((void**)&hostMem, memSizeHost));
  CUDA_SAFE_CALL(cudaMalloc((void **) &deviceMem, memSizeDevice));   // Allocate array on device
  // Initialize GPU memory to nan and host memory to zero
  CUDA_SAFE_CALL(cudaMemset(deviceMem, 255, memSizeDevice));
  memset(hostMem, 0, memSizeHost);
 // Ensure memory allocation functions worked correctly.
  if(hostMem == NULL)
    printf("Error -- Failed to allocate host memory!\n");
    exit(EXIT_FAILURE);
 if(deviceMem == NULL)
    printf("Error -- Failed to allocate device memory!\n");
    exit(EXIT_FAILURE);
 // Create input data array.
  createArray(hostMem, memSizeHost/sizeof(Complex));
 // Create FFT plan
  cufftHandle plan;
  CUFFT_SAFE_CALL(cufftPlan1d(&plan, fftSize, CUFFT_C2C, batchSize));
 int ioi = 13;
  int idx = 0;
  if (0)
    // Synchronous Processing
    // This modifies some of the host memory.  If we see it after copying back the data
    //   from the GPU to the host machine, the copy did not work.
    hostMem[ioi].x = -131313;
  else
    // Asychronous Processing
    cudaEvent_t event;
    cudaEventCreate(&event);
    cudaEventRecord(event, 0);
    cudaMemcpyAsync(deviceMem, &(hostMem[idx]), memSizeDevice, cudaMemcpyHostToDevice, 0);
    cufftExecC2C(plan, (cufftComplex *)deviceMem, (cufftComplex *)deviceMem, CUFFT_FORWARD);
   cudaMemcpyAsync(&(hostMem[idx]), deviceMem, memSizeDevice, cudaMemcpyHostToDevice, 0);
    //cudaThreadSynchronize();
    //cudaEventSynchronize(event);
    while (cudaEventQuery(event) == cudaErrorNotReady)
      printf("In while loop.\n");
      usleep(1000);
    CUDA_SAFE_CALL(cudaEventDestroy(event));
 // Display result
  printf("Result: %d = %f +%fi\n", ioi, hostMem[ioi].x, hostMem[ioi].y);
  printf("-----------------------------\n");
  printf("If test passed, result should be: 13 = -13342.587891 +12318.576172i\n");
  printf("If FFT and GPU memcpy did not occur, result should be: Result: 13 = -131313.000000 +13.000000i\n");
 // Free memory
  cudaFreeHost(hostMem);
  cudaFree(deviceMem);
 return EXIT_SUCCESS;
  unsigned int a;
  int status;
  float timeVal;
  timeVal = time(NULL);
  srand(timeVal);
  //printf("timeVal = %f\n", timeVal);
 for(a = 0;a < arrayLength;++a)
    arrayPtr[a].x = a;
    arrayPtr[a].y = a;
    //printf("%d = %f +%fi\n", a, arrayPtr[a].x, arrayPtr[a].y);
  status = 1;
  //printf("%d = %f +%fi\n", 3, arrayPtr[3].x, arrayPtr[3].y);
 return status;
When I run it, I get the following output:
[root@localhost CudaFFTBenchmark]# asyncFftTest
Using device 0: GeForce GTX 280
In while loop.
See above post.
Found the mistake, the second async memcpy should not be:
but should be
Whoops! Sorry!
