Hi, I ran into a performance issue using the CUDA driver API to set a shared memory carveout before submitting a kernel. I have a multi-threaded application where I’d like to submit overlapping memory transfers and kernel launches from several threads. Ideally, kernels of one thread should launch and execute at the same time a memory transfer launched from another thread is in progress. That is indeed happenning correctly until I need to specify the shared memory carveout for a kernel using cuFuncSetAttribute with either CU_FUNC_ATTRIBUTE_MAX_DYNAMIC_SHARED_SIZE_BYTES or CU_FUNC_ATTRIBUTE_PREFERRED_SHARED_MEMORY_CARVEOUT. I need to do this, because cuLaunchKernel fails for dynamic shared memory allocations above 48 kB without the attribute.
I found that cuFuncSetAttribute introduces a lock which seems to be waiting until the async memcpy finishes. It happens regardless of the number passed in there (even 1 byte). Naively, I thought these operations should have no dependency, so I’m puzzled why this is happening.
Here’s a minimal reproducer:
#include <cuda.h>
#include <iostream>
#include <thread>
#include <chrono>
#include <pthread.h>
#include <vector>
#include <cstring>
#define CHECK(x) do { \
auto err{x}; \
if (err!=CUDA_SUCCESS) { \
std::cerr << "CUDA Error " \
<< err << " in " #x << "\n"; \
} while (0)
unsigned int blockSize = 480;
unsigned int num_elements = 1201920;
CUfunction kernel_function;
float value_to_add{1.0f};
bool set_attr{false};
bool verifyOutput(float *outputData, int num) {
for (int i = 0; i < num; ++i) {
if ((outputData[i] != 1.0f)) return false;
return true;
void doWork(int iterationsPerThread,
int num_kernel_calls, float *inputData, float *outputData,
int threadId, CUstream stream, CUdeviceptr d_inputData,
CUdeviceptr d_outputData) {
inputData = inputData + threadId*num_elements;
outputData = outputData + threadId*num_elements;
unsigned int gridSize = (num_elements + blockSize - 1) / blockSize;
for (int i = 0; i < iterationsPerThread; i++) {
CHECK(cuMemcpyHtoDAsync(d_inputData, inputData, num_elements * sizeof(float), stream));
for (int k = 0; k < num_kernel_calls; k++) {
void* args[4] = {&d_inputData, &d_outputData, &value_to_add, &num_elements};
if (set_attr) {
CHECK(cuFuncSetAttribute(kernel_function, CU_FUNC_ATTRIBUTE_MAX_DYNAMIC_SHARED_SIZE_BYTES, 1));
CHECK(cuLaunchKernel(kernel_function, gridSize, 1, 1, blockSize, 1, 1, 0, stream, args, 0));
CHECK(cuMemcpyDtoHAsync(outputData, d_outputData, num_elements * sizeof(float), stream));
int main(int argc, char** argv) {
if (argc > 1) {
if (std::string{argv[1]} == "-a") {
set_attr = true;
int numThreads = 4;
int totalIterations = 500;
int num_kernel_calls = 100;
int iterationsPerThread = totalIterations / numThreads;
std::cout << "Threads: " << numThreads << " Total iterations: " << totalIterations << " Iterations per thread: " << iterationsPerThread << "\n";
float* inputData;
float* outputData;
inputData = static_cast<float*>(malloc(num_elements * numThreads * sizeof(float)));
outputData = static_cast<float*>(malloc(num_elements * numThreads * sizeof(float)));
memset(inputData, 0, num_elements * numThreads * sizeof(float));
memset(outputData, 0, num_elements * numThreads * sizeof(float));
CUdevice device;
CUcontext context;
CUmodule module;
CHECK(cuInit(0));
CHECK(cuDeviceGet(&device, 0));
CHECK(cuCtxCreate(&context, 0, device));
CHECK(cuDevicePrimaryCtxRetain(&context, device));
CHECK(cuModuleLoad(&module, "kernel.ptx"));
CHECK(cuModuleGetFunction(&kernel_function, module, "add_value"));
CUstream streams[numThreads];
CUdeviceptr d_inputDataList[numThreads];
CUdeviceptr d_outputDataList[numThreads];
for (int threadId = 0; threadId < numThreads; ++threadId) {
CHECK(cuStreamCreate(&streams[threadId], CU_STREAM_NON_BLOCKING));
CHECK(cuMemAlloc(&d_inputDataList[threadId], num_elements*sizeof(float)));
CHECK(cuMemAlloc(&d_outputDataList[threadId], num_elements*sizeof(float)));
std::vector<std::thread> threads;
auto start_time{std::chrono::high_resolution_clock::now()};
threads.push_back(std::thread(
doWork, iterationsPerThread, num_kernel_calls, inputData, outputData,
threadId, streams[threadId], d_inputDataList[threadId], d_outputDataList[threadId]));
for (int i = 0; i < threads.size(); i++) {
threads[i].join();
CHECK(cuCtxSynchronize());
auto end_time{std::chrono::high_resolution_clock::now()};
std::cout << "Total time: "
<< std::chrono::duration_cast<std::chrono::duration<double>>(end_time - start_time).count()
<< " s" << std::endl;
if (verifyOutput(outputData, num_elements*numThreads)) {
std::cout << "Verification succeeded" << std::endl;
} else {
std::cout << "Verification failed" << std::endl;
return 0;
with a minimal kernel code:
extern "C" __global__ void add_value(float *inputData, float *outputData, float add_value, unsigned int num_elements) {
unsigned int tid = threadIdx.x + blockIdx.x * blockDim.x;
if (tid < num_elements)
outputData[tid] = inputData[tid] + add_value;
and I run it like this:
# compile
export CUDA_ARCH=sm_86
nvcc -arch=${CUDA_ARCH} -o kernel.o -c kernel.cu
cuobjdump -ptx kernel.o | sed -n '/^\.version/,$p' > kernel.ptx
nvcc -arch=${CUDA_ARCH} -o main main-cuda.cpp -lcuda
# run without cuFuncSetAttribute
./main
# run with cuFuncSetAttribute
./main -a
The hardcoded totalIterations and num_kernel_calls reproduce this well on my PC with RTX 3060, but may need adjusting for bigger/faster hardware.
Here’s what I see in Nsight Systems - without cuFuncSetAttribute above (overlapping operations) and with cuFuncSetAttribute below (locking):
We can see that pthread_rwlock_wrlock appears in the system trace and no new API calls are made while the async memcpy is ongoing. It looks like the other threads wait on a lock inside cuFuncSetAttribute.
What is the reason for this synchronisation and is this documented somewhere? Is there any way to avoid it and still launch kernels with large shared memory allocations?
