When using Cuda Toolkits 12.8.0 and 12.9.0 on an NVIDIA GA100, I encounter the error CUPTI_ERROR_INVALID_METRIC_NAMEfor cuptiProfilerHostGetSubMetrics. However, in Cuda Toolkit 13.0.0 cuptiProfilerHostGetSubMetricswill succeed.
Workflow that can reproduce the error:
#include <iostream>
#include <vector>
#include <cupti_profiler_host.h>
#include <cupti_profiler_target.h>
#include <cuda_runtime_api.h>
#include <cupti_target.h>
int main()
CUresult cu_res = cuInit(0);
if (cu_res != CUDA_SUCCESS) {
std::cout << "Call to cuptiProfilerInitialize failed with error code: " << cu_res << std::endl;
exit(EXIT_FAILURE);
CUpti_Profiler_Initialize_Params profilerInitializeParams {};
profilerInitializeParams.structSize = CUpti_Profiler_Initialize_Params_STRUCT_SIZE;
CUptiResult cupti_res = cuptiProfilerInitialize(&profilerInitializeParams);
if (cupti_res != CUPTI_SUCCESS) {
std::cout << "Call to cuptiProfilerInitialize failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
CUcontext context;
unsigned int flags = 0;
int device_index = 0;
#if CUDART_VERSION >= 13000
cu_res = cuCtxCreate(&context, (CUctxCreateParams*)0, flags, device_index);
#else
cu_res = cuCtxCreate(&context, flags, device_index);
#endif
std::cout << "Call to cuCtxCreate failed with error code: " << cu_res << std::endl;
exit(EXIT_FAILURE);
std::vector<uint8_t> counter_availability_image;
CUpti_Profiler_GetCounterAvailability_Params getCounterAvailabilityParams {};
getCounterAvailabilityParams.structSize = CUpti_Profiler_GetCounterAvailability_Params_STRUCT_SIZE;
getCounterAvailabilityParams.ctx = context;
#if CUDART_VERSION >= 13010
getCounterAvailabilityParams.bAllowDeviceLevelCounters = 1;
#endif
cupti_res = cuptiProfilerGetCounterAvailability(&getCounterAvailabilityParams);
std::cout << "Call to cuptiProfilerGetCounterAvailability failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
counter_availability_image.resize(getCounterAvailabilityParams.counterAvailabilityImageSize);
getCounterAvailabilityParams.pCounterAvailabilityImage = counter_availability_image.data();
getCounterAvailabilityParams.counterAvailabilityImageSize = counter_availability_image.size();
std::cout << "Second call to cuptiProfilerGetCounterAvailability failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
CUpti_Device_GetChipName_Params getChipNameParams {};
getChipNameParams.structSize = CUpti_Device_GetChipName_Params_STRUCT_SIZE;
getChipNameParams.deviceIndex = device_index;
cupti_res = cuptiDeviceGetChipName(&getChipNameParams);
std::cout << "Call to cuptiDeviceGetChipName failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
const char *chip_name = getChipNameParams.pChipName;
CUpti_Profiler_Host_Initialize_Params initializeParams {};
initializeParams.structSize = CUpti_Profiler_Host_Initialize_Params_STRUCT_SIZE;
initializeParams.profilerType = CUPTI_PROFILER_TYPE_RANGE_PROFILER;
initializeParams.pChipName = chip_name;
initializeParams.pCounterAvailabilityImage = counter_availability_image.data();
#if CUDART_VERSION >= 13020
// Only valid for PM sampling and can be set to NULL for CUPTI Range Profiler.
initializeParams.pSinglePassMetricSetName = NULL;
#endif
cupti_res = cuptiProfilerHostInitialize(&initializeParams);
std::cout << "Call to cuptiProfilerHostInitialize failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
CUpti_Profiler_Host_Object *host_object= initializeParams.pHostObject;
for (size_t metric_type = 0; metric_type < CUPTI_METRIC_TYPE__COUNT; metric_type++) {
CUpti_Profiler_Host_GetBaseMetrics_Params getBaseMetricsParams {};
getBaseMetricsParams.structSize = CUpti_Profiler_Host_GetBaseMetrics_Params_STRUCT_SIZE;
getBaseMetricsParams.pHostObject = host_object;
getBaseMetricsParams.metricType = (CUpti_MetricType) metric_type;
cupti_res = cuptiProfilerHostGetBaseMetrics(&getBaseMetricsParams);
std::cout << "Call to cuptiProfilerHostGetBaseMetrics failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
const char **base_metric_names = getBaseMetricsParams.ppMetricNames;
size_t number_of_base_metrics = getBaseMetricsParams.numMetrics;
for (size_t base_metric_idx = 0; base_metric_idx < number_of_base_metrics; base_metric_idx++) {
const char *base_metric_name = base_metric_names[base_metric_idx];
CUpti_Profiler_Host_GetSubMetrics_Params getSubMetricsParams {};
getSubMetricsParams.structSize = CUpti_Profiler_Host_GetSubMetrics_Params_STRUCT_SIZE;
getSubMetricsParams.pHostObject = host_object;
getSubMetricsParams.metricType = (CUpti_MetricType) metric_type;
getSubMetricsParams.pMetricName = base_metric_name;
cupti_res = cuptiProfilerHostGetSubMetrics(&getSubMetricsParams);
std::cout << "Call to cuptiProfilerHostGetSubMetrics failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
CUpti_Profiler_Host_Deinitialize_Params hostDeinitializeParams {};
hostDeinitializeParams.structSize = CUpti_Profiler_Host_Deinitialize_Params_STRUCT_SIZE;
hostDeinitializeParams.pHostObject = host_object;
cupti_res = cuptiProfilerHostDeinitialize(&hostDeinitializeParams);
std::cout << "Call to cuptiProfilerHostDeinitialize failed with error code: " << cupti_res << std::endl;
exit(EXIT_FAILURE);
host_object = nullptr;
cu_res = cuCtxDestroy(context);
std::cout << "Call to cuCtxDestroy failed with error code: " << cu_res << std::endl;
exit(EXIT_FAILURE);
return 0;
To compile the above workflow:
export CUDA_HOME=/path/to/ctk/root/dir
nvcc -I$CUDA_HOME/extras/CUPTI/include -I$CUDA_HOME/include your_filename.cu -o your_filename -L$CUDA_HOME/extras/CUPTI/lib64 -lcupti -lcuda
From further testing with Cuda Toolkit 12.9.0, I have found adding a rollup metric when applicable to the base metric name will resolve the error. Do you need more than just the base metric name in Cuda Toolkits < 13.0.0 to get the sub metrics?
