Custom model in Deepstream
• Hardware Platform (Jetson / GPU) gpu
• DeepStream Version 7
• TensorRT Version 8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) t4
**• Issue Type( questions, new requirements, bugs)**question
Hi
I have an onnx model and i want to add it into deepstream
I have 2 question
I wanna know can i use my custom moden in deepstream using python?
Is there any example ?
Sure. To custom the model, you need to choose which inferencing method do you want. We have provided nvinfer DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums and nvinferserver DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums.
And you must know which preprocessing and postprocessing the model needs.
There are lots of samples in NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream (github.com)
Thank for response
Did you mean if my model give me somthing like this prob-class1(0 or 1)-class 2(0 or 1)- bounding boxes
Then i can use it in deepstream by setting this items to metafile using preprocessing and post processing?
Do you mean your model is a detector?
A model with Both detector and classification
Then you need to customize the postprocessing.
We have postprocessing sample in /opt/nvidia/deepstream/deepstream/sources/objectDetector_Yolo
Or deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
