CV::CUDA::MAT Creation using NvEGLImageFromFd Missing in Jetpack5
Hi All,
I have been using Jetpack4 for quite a long time and now upgrading to jetpack5,
Previously I used the following snippet to convert an nvbuf into GPU mat
            EGLImageKHR egl_image;
            egl_image = NvEGLImageFromFd(/*g_display.get()*/NULL, m_dmabufs[0]);
            // printf("NV EGLIMAGE FROM FD\n");
            CUresult status;
            CUeglFrame eglFrame;
            CUgraphicsResource pResource = NULL;
            cudaFree(0);
            status = cuGraphicsEGLRegisterImage(&pResource,
                        egl_image,
                        CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
            // printf("CU GRAPHICS REGISTER IMAGE\n");
            if (status != CUDA_SUCCESS)
                printf("cuGraphicsEGLRegisterImage failed: %d \n",status);
            // printf("CONSUMERTHREAD GET MAPPED EGL FRAME\n");
            status = cuGraphicsResourceGetMappedEglFrame(&eglFrame, pResource, 0, 0);
            status = cuCtxSynchronize();
            // cv::cuda::GpuMat d_mat(STREAM_SIZE.height(), STREAM_SIZE.width(), CV_8UC4, eglFrame.frame.pPitch[0]);
But I am not able to find the method “NvEGLImageFromFd“ seems it has been removed.
Is there any way to convert the “iNativeBuffer->copyToNvBuffer(m_dmabufs[0]) “ into a GPU MAT??
Thanks In Advance
Hi
Please find the sample below to see if it helps:
/usr/src/jetson_multimedia_api/samples/04_video_dec_trt
