Hello moezruo6,
For the very first frame, it should be _nvFrame.reset = true; , afterwards set _nvFrame.reset = false;
I noticed _nvFrame.objectsIn.detectionDone = false; There is a difference in KLT and NvDCF in handling this flag. In KLT, it doesn’t check this flag, and if there’s bbox from detector, it will use it. But, NvDCF checks this flag. So, if you provide bbox to initialize the tracker, then you should set this _nvFrame.objectsIn.detectionDone = true; For example, if you run detector at every other frame, then this flag value should also alternate between true and false.
If you run detector at every frame (which is the case in your sample code), then this flag should always be true.
Please try and post your observation again.
