Deadlock on cudaMalloc and cudaMemcpyDtoH in different thread in the same process
Hi, I met a deadlock problem recently when using NCCL to do some simple send/recv operations, and here I summarise a minimum reproduction version: https://pastebin.com/bM9RNgH5
The deadlock happens when one thread is trying to malloc some memory and another thread is trying to memcpy from device to host, and it has 100% to reproduce.
The final backtrace of gdb of the two threads mentioned above is:
I really want to know the reason why these two operations would have conflict or something else, making the deadlock.
Operation system: Ubuntu 20.04
Cuda version: 11.4
NCCL Version: 2.17.3
Thanks for your help in advance.
please don’t post pictures of text on this forum.
I’m not able to conveniently access pastebin. It should be possible to create a test case and use the forum tools to post it here, inline, in a posting.
Sorry for my ignorance. It’s my first time looking for help here. Here’s the minimum reproducible code:
export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$PWD/nccl_2.17.1-1+cuda11.0_x86_64/lib/:$LD_LIBRARY_PATH
export LIBRARY_PATH=/usr/local/cuda/lib64:$PWD/nccl_2.17.1-1+cuda11.0_x86_64/lib/:$LIBRARY_PATH
export C_INCLUDE_PATH=/usr/local/cuda/include/:$PWD/nccl_2.17.1-1+cuda11.0_x86_64/include/:$C_INCLUDE_PATH
export CPLUS_INCLUDE_PATH=/usr/local/cuda/include/:$PWD/nccl_2.17.1-1+cuda11.0_x86_64/include/:$CPLUS_INCLUDE_PATH
g++ send_recv.cc -lpthread -lcudart -lnccl
#include <unistd.h>
#include <cassert>
#include <chrono>
#include <functional>
#include <iostream>
#include <memory>
#include <mutex>
#include <string>
#include <thread>
#include <vector>
#include "cuda_runtime.h"
#include "nccl.h"
ncclUniqueId ncclId;
#define CUDACHECK(cmd)                                              \
  do {                                                              \
    cudaError_t e = cmd;                                            \
    if (e != cudaSuccess) {                                         \
      printf("Failed: Cuda error %s:%d '%s'\n", __FILE__, __LINE__, \
             cudaGetErrorString(e));                                \
      assert(false);                                                \
  } while (0)
#define NCCLCHECK(cmd)                                              \
  do {                                                              \
    ncclResult_t r = cmd;                                           \
    if (r != ncclSuccess) {                                         \
      printf("Failed, NCCL error %s:%d '%s'\n", __FILE__, __LINE__, \
             ncclGetErrorString(r));                                \
      assert(false);                                                \
  } while (0)
#define ASYNC 1
const int device_count = 4;
void custom_recv(int dev_id, int device_count) {
    cudaSetDevice(dev_id);
    ncclComm_t comm;
    #if NCCL_VERSION >= 21700
    ncclConfig_t config = NCCL_CONFIG_INITIALIZER;
    NCCLCHECK(ncclCommInitRankConfig(&comm, device_count, ncclId, dev_id, &config));
    #else
    NCCLCHECK(ncclCommInitRank(&comm, device_count, ncclId, dev_id));
    #endif
    cudaStream_t stream;
    CUDACHECK(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
    void* buffer;
    CUDACHECK(cudaMalloc(&buffer, sizeof(float)));
    ncclGroupStart();
    NCCLCHECK(ncclRecv(buffer, 1, ncclFloat32, 0, comm, stream));
    ncclGroupEnd();
    float host_buf;
    #if ASYNC
    CUDACHECK(cudaMemcpyAsync(&host_buf, buffer, sizeof(float), cudaMemcpyDeviceToHost, stream));
    // void* buffer2;
    // CUDACHECK(cudaMallocAsync(&buffer2, sizeof(float)*1024, stream));
    // CUDACHECK(cudaStreamSynchronize(stream));
    #else
    cudaStream_t copy_stream;
    CUDACHECK(cudaStreamCreateWithFlags(&copy_stream, cudaStreamNonBlocking));
    CUDACHECK(cudaMemcpyAsync(&host_buf, buffer, sizeof(float), cudaMemcpyDeviceToHost, copy_stream));
    #endif
    assert(host_buf == 1);
end:
    std::cout << "device " << dev_id << " recv done" << std::endl;
int main(int argc, char** argv) {
    NCCLCHECK(ncclGetUniqueId(&ncclId));
    // send thread, 0 -> 1 2 3
    std::thread thr0([]() {
      cudaSetDevice(0);
      ncclComm_t comm;
      NCCLCHECK(ncclCommInitRankConfig(&comm, device_count, ncclId, 0, &config));
      #else
      NCCLCHECK(ncclCommInitRank(&comm, device_count, ncclId, 0));
      #endif
      void* buffer[device_count];
      for (int i = 1; i < device_count; i++) {
        CUDACHECK(cudaMalloc(&buffer[i], sizeof(float)));
      float r = 1;
        CUDACHECK(cudaMemcpy(buffer[i], &r, sizeof(float), cudaMemcpyHostToDevice));
      NCCLCHECK(ncclGroupStart());
        NCCLCHECK(ncclSend(buffer[i], 1, ncclFloat32, i, comm, stream));
      NCCLCHECK(ncclGroupEnd());
      std::cout << "device 0 send done" << std::endl;
    // recv thread: i <- 0
    std::vector<std::thread> threads;
      threads.push_back(std::thread(custom_recv, i, device_count));
    thr0.join();
    for (auto& thr : threads) {
      thr.join();
