Hello!
Trying to repeat the example from the book. It simulates heat transfer.
Consider two options:
- Without texture memory
- Using texture memory
The source code is given below.
The book states that the second option should work faster than the first.
And I get the opposite:
- 63 ms per frame
- 380 ms per frame
Graphics Processor: GeForce GTX 1060 with Max-Q Design
Can you please tell me why it happens?
Thanks you!
First
#include <stdio.h>
#include <cuda.h>
#include <book.h>
#include <cpu_anim.h>
#define DIM 1024
#define SPEED 0.25f
#define MAX_TEMP 1.0f
#define MIN_TEMP 0.0001f
#define PI 3.1415926535897932f
struct DataBlock {
unsigned char *output_bitmap;
float *dev_inSrc;
float *dev_outSrc;
float *dev_constSrc;
CPUAnimBitmap *bitmap;
cudaEvent_t start, stop;
float totalTime;
float frames;
__global__ void copy_const_kernel( float *iptr, const float *cptr ) {
int x = threadIdx.x + blockIdx.x * blockDim.x;
int y = threadIdx.y + blockIdx.y * blockDim.y;
int offset = x + y * blockDim.x * gridDim.x;
if(cptr[offset] != 0) iptr[offset] = cptr[offset];
__global__ void blend_kernel( float *outSrc, const float *inSrc) {
int left = offset - 1;
int right = offset + 1;
if(x == 0) left++;
if(x == DIM-1) right--;
int top = offset - DIM;
int bottom = offset + DIM;
if(y == 0) top += DIM;
if(y == DIM-1) bottom -= DIM;
outSrc[offset] = inSrc[offset] + SPEED * ( inSrc + inSrc + inSrc[bottom] + inSrc[top]- inSrc[offset] *4 );
void anim_gpu( DataBlock *d, int ticks ) {
HANDLE_ERROR (cudaEventRecord( d->start, 0) );
dim3 blocks(DIM/16, DIM/16);
dim3 threads(16, 16);
CPUAnimBitmap *bitmap = d->bitmap;
for(int i=0; i<90; i++) {
copy_const_kernel<<<blocks,threads>>>( d->dev_inSrc, d->dev_constSrc );
blend_kernel<<<blocks,threads>>>( d->dev_outSrc, d->dev_inSrc );
swap ( d->dev_inSrc, d->dev_outSrc );
float_to_color<<<blocks,threads>>>(d->output_bitmap, d->dev_inSrc);
HANDLE_ERROR( cudaMemcpy( bitmap->get_ptr(),
d->output_bitmap,
bitmap->image_size(),
cudaMemcpyDeviceToHost ) );
HANDLE_ERROR (cudaEventRecord( d->stop, 0) );
HANDLE_ERROR (cudaEventSynchronize( d->stop) );
float elapsedTime;
HANDLE_ERROR( cudaEventElapsedTime( &elapsedTime,
d->start, d->stop ) );
d->totalTime += elapsedTime;
++d->frames;
printf( "Average one frame time: %3.1f ms\n", d->totalTime / d->frames );
void anim_exit( DataBlock *d) {
HANDLE_ERROR( cudaFree( d->dev_inSrc ) );
HANDLE_ERROR( cudaFree( d->dev_outSrc ) );
HANDLE_ERROR( cudaFree( d->dev_constSrc ) );
HANDLE_ERROR( cudaEventDestroy( d->start ));
HANDLE_ERROR( cudaEventDestroy( d->stop ));
int main( void ) {
DataBlock data;
CPUAnimBitmap bitmap( DIM, DIM, &data );
data.bitmap = &bitmap;
data.totalTime = 0;
data.frames = 0;
HANDLE_ERROR( cudaEventCreate( &data.start ) );
HANDLE_ERROR( cudaEventCreate( &data.stop ) );
int imageSize = bitmap.image_size();
HANDLE_ERROR( cudaMalloc( (void**)&data.output_bitmap,
imageSize ) );
HANDLE_ERROR( cudaMalloc( (void**)&data.dev_inSrc,
imageSize ) );
HANDLE_ERROR( cudaMalloc( (void**)&data.dev_outSrc,
imageSize ) );
HANDLE_ERROR( cudaMalloc( (void**)&data.dev_constSrc,
imageSize ) );
// intialize the constant data
float *temp = (float*)malloc( imageSize );
for (int i=0; i<DIM*DIM; i++) {
temp[i] = 0;
int x = i % DIM;
int y = i / DIM;
if ((x>300) && (x<600) && (y>310) && (y<601))
temp[i] = MAX_TEMP;
temp[DIM*100+100] = (MAX_TEMP + MIN_TEMP)/2;
temp[DIM*700+100] = MIN_TEMP;
temp[DIM*300+300] = MIN_TEMP;
temp[DIM*200+700] = MIN_TEMP;
for (int y=800; y<900; y++) {
for (int x=400; x<500; x++) {
temp[x+y*DIM] = MIN_TEMP;
HANDLE_ERROR( cudaMemcpy( data.dev_constSrc, temp,
imageSize,
cudaMemcpyHostToDevice ) );
// initialize the input data
for (int y=800; y<DIM; y++) {
for (int x=0; x<200; x++) {
temp[x+y*DIM] = MAX_TEMP;
HANDLE_ERROR( cudaMemcpy( data.dev_inSrc, temp,
imageSize,
free( temp );
bitmap.anim_and_exit( (void (*)(void*,int))anim_gpu,
(void (*)(void*))anim_exit );
Second
#include <stdio.h>
#include <cuda.h>
#include <book.h>
#define DIM 1024
#define SPEED 0.25f
// these exist on the GPU side
texture<float,2> texConstSrc;
texture<float,2> texIn;
texture<float,2> texOut;
__global__ void blend_kernel( float *dst,
bool dstOut ) {
// map from threadIdx/BlockIdx to pixel position
float t, l, c, r, b;
if (dstOut) {
t = tex2D(texIn,x,y-1);
l = tex2D(texIn,x-1,y);
c = tex2D(texIn,x,y);
r = tex2D(texIn,x+1,y);
b = tex2D(texIn,x,y+1);
} else {
t = tex2D(texOut,x,y-1);
l = tex2D(texOut,x-1,y);
c = tex2D(texOut,x,y);
r = tex2D(texOut,x+1,y);
b = tex2D(texOut,x,y+1);
dst[offset] = c + SPEED * (t + b + r + l - 4 * c);
__global__ void copy_const_kernel( float *iptr ) {
float c = tex2D(texConstSrc,x,y);
if (c != 0)
iptr[offset] = c;
// globals needed by the update routine
struct DataBlock {
float *dev_inSrc;
float *dev_outSrc;
float totalTime;
float frames;
HANDLE_ERROR( cudaEventRecord( d->start, 0 ) );
dim3 blocks(DIM/16,DIM/16);
dim3 threads(16,16);
// since tex is global and bound, we have to use a flag to
// select which is in/out per iteration
volatile bool dstOut = true;
for (int i=0; i<90; i++) {
float *in, *out;
if (dstOut) {
in = d->dev_inSrc;
out = d->dev_outSrc;
} else {
out = d->dev_inSrc;
in = d->dev_outSrc;
copy_const_kernel<<<blocks,threads>>>( in );
blend_kernel<<<blocks,threads>>>( out, dstOut );
dstOut = !dstOut;
float_to_color<<<blocks,threads>>>( d->output_bitmap,
d->dev_inSrc );
d->output_bitmap,
HANDLE_ERROR( cudaEventRecord( d->stop, 0 ) );
HANDLE_ERROR( cudaEventSynchronize( d->stop ) );
float elapsedTime;
++d->frames;
printf( "Average Time per frame: %3.1f ms\n",
d->totalTime/d->frames );
// clean up memory allocated on the GPU
void anim_exit( DataBlock *d ) {
cudaUnbindTexture( texIn );
cudaUnbindTexture( texOut );
cudaUnbindTexture( texConstSrc );
HANDLE_ERROR( cudaEventDestroy( d->start ) );
HANDLE_ERROR( cudaEventDestroy( d->stop ) );
int main( void ) {
DataBlock data;
data.totalTime = 0;
data.frames = 0;
imageSize ) );
// assume float == 4 chars in size (ie rgba)
imageSize ) );
imageSize ) );
imageSize ) );
cudaChannelFormatDesc desc = cudaCreateChannelDesc<float>();
HANDLE_ERROR( cudaBindTexture2D( NULL, texConstSrc,
data.dev_constSrc,
desc, DIM, DIM,
sizeof(float) * DIM ) );
HANDLE_ERROR( cudaBindTexture2D( NULL, texIn,
data.dev_inSrc,
desc, DIM, DIM,
HANDLE_ERROR( cudaBindTexture2D( NULL, texOut,
data.dev_outSrc,
desc, DIM, DIM,
// initialize the constant data
temp[i] = 0;
int x = i % DIM;
int y = i / DIM;
temp[i] = MAX_TEMP;
imageSize,
imageSize,
free( temp );
