Deepseek V4.1 Flash Deprecated
Hello. Apparently Despseek Flash V4.1 got deprecated without any explanation. Could we know why please?. Many people here used it…
Or at least. Will it be replaced with another Deekseep model?. Because as of right now there is none available on NIM…
Thanks in advance.
It got deprecated because this platform is mainly used as a way to test models and it’s not intended for production, they can deprecate models whenever they want. You shouldn’t rely on NIM as it’s getting worse and worse.
I have to give them credit for finally deleting deprecated endpoints such as moonshotai/kimi-k2.6 and many others.
That’s sad but i see. Although it’s weird because everytime they deprecate a Deepseek model they also update it with it’s last version so we don’t say with nothing…but this time they didn’t.
I hope the devs plan to do it, because sadly i can’t find another free alternative to NIM even if it is getting worse…
Get used to the idea that NIM won’t get any better. You will have to search for other alternatives.
Thanks for the tip. Any alternative you can recommend?.
I’m in the same boat as you. It’s hard to find reasonable free trials without additional caveats. Maybe try AIHubMix, they have free models with use limits. I don’t have any experience with it so you’ll have to do your research.
Nim isn’t supposed to be your own free unlimited API. It’s to test out models. Deepseek’s API is crazy cheap, and on Opencode $40 gets you $200 of Deepseek. Why do you think you deserve free unlimited usage
Thanks, i will try. Although i hope Deepseek can return here soon too.
usually, the new model wont last long
openrouter is good, but 50rpd is kinda harsh
