• Hardware Platform (Jetson / GPU): Jetson Nano 4gb Dev Board
• DeepStream Version: nvcr.io/nvidia/deepstream-l4t:6.0.1-base
• JetPack Version (valid for Jetson only):
cat /etc/nv_tegra_release
# R32 (release), REVISION: 7.1, GCID: 29818004, BOARD: t210ref, EABI: aarch64, DATE: Sat Feb 19 17:05:08 UTC 2022
• TensorRT Version: NA
• Issue Type( questions, new requirements, bugs): questions/bug
I build the deepstream_lpr_app based on the steps from:
for build I was using the ‘nvcr.io/nvidia/deepstream-l4t:6.0.1-samples’. As I was using the deepstream docker image I could skip the corresponding step in the ’ Prerequisition’ chapter, to be able to build the app I only needed to install the following packages:
- libgstreamer1.0-dev
- libgstreamer-plugins-base1.0-dev
dokcer command:
docker run --rm -ti\
--net=host -e DISPLAY=$DISPLAY -w '/sources/tmp/deepstream_lpr_app-master/deepstream-lpr-app' -v /tmp/.X11-unix/:/tmp/.X11-unix\
-v /home/pettair/sources:/sources\
nvcr.io/nvidia/deepstream-l4t:6.0.1-base\
bash
After this I tried to execute the build binary from ‘deepstream-l4t:6.0.1-base’:
bash
but I get the following error:
./deepstream-lpr-app 1 1 0 /sources/input.mp4 /sources/output.mp4
nvbuf_utils: Could not get EGL display connection
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
No EGL Display
nvbufsurftransform: Could not get EGL display connection
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:48): GStreamer-WARNING **: 19:07:25.218: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:54): GStreamer-WARNING **: 19:07:25.665: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
One element could not be created. Exiting.
The output is the same if I try to execute it from the container that I used for the build.
I expected that I would be able to run the application in a base container. Im very new to the topic so it is possible that im doing something wrong, my perception was that i would have a “fat” docker image with all the dependencies what I can use for building and a “slim” which is only used in execution. Can you help me what im missing here?
Peter
