Deepstream_lpr_app for DS6 - libcufft.so.10: cannot open shared object
• Hardware (T4)
• Network Type (deepstream_lpr_app sample)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
attcloud@deepstream-dev-02-vm:~/deepstream_lpr_app/deepstream-lpr-app$ sudo ./deepstream-lpr-app 1 2 0 Driving.mp4 output.264
Request sink_0 pad from streammux
Warning: ‘input-dims’ parameter has been deprecated. Use ‘infer-dims’ instead.
Now playing: 1
WARNING: [TRT]: TensorRT was linked against cuBLAS/cuBLAS LT 11.5.1 but loaded cuBLAS/cuBLAS LT 11.3.0
0:00:01.338099280 15393 0x55b68b87e0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 3]: deserialized trt engine from :/home/attcloud/deepstream_lpr_app/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT image_input 3x48x96 min: 1x3x48x96 opt: 4x3x48x96 Max: 16x3x48x96
1 OUTPUT kINT32 tf_op_layer_ArgMax 24 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT tf_op_layer_Max 24 min: 0 opt: 0 Max: 0
ERROR: [TRT]: 3: Cannot find binding of given name: output_bbox/BiasAdd
0:00:01.338219042 15393 0x55b68b87e0c0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1868> [UID = 3]: Could not find output layer ‘output_bbox/BiasAdd’ in engine
ERROR: [TRT]: 3: Cannot find binding of given name: output_cov/Sigmoid
0:00:01.338237647 15393 0x55b68b87e0c0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1868> [UID = 3]: Could not find output layer ‘output_cov/Sigmoid’ in engine
0:00:01.338248488 15393 0x55b68b87e0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 3]: Use deserialized engine model: /home/attcloud/deepstream_lpr_app/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
0:00:01.339328939 15393 0x55b68b87e0c0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 3]: Load new model:lpr_config_sgie_us.txt sucessfully
0:00:01.355299185 15393 0x55b68b87e0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 2]: deserialized trt engine from :/home/attcloud/deepstream_lpr_app/models/LP/LPD/usa_pruned.etlt_b16_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x480x640
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x30x40
2 OUTPUT kFLOAT output_cov/Sigmoid 1x30x40
0:00:01.355360764 15393 0x55b68b87e0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 2]: Use deserialized engine model: /home/attcloud/deepstream_lpr_app/models/LP/LPD/usa_pruned.etlt_b16_gpu0_int8.engine
0:00:01.356877468 15393 0x55b68b87e0c0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:lpd_us_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
dlopen error: libcufft.so.10: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
Running…
Could you double check the CUDA installation? Thanks.
For example, can you find any file as below?
$ sudo find /usr/local -name libcufft.so*
Maybe something mismatching on your machine.
Hi Morganh,
The result came back empty… Is this mean the Cuda installation was bad?
attcloud@deepstream-dev-02-vm:~/deepstream_lpr_app/deepstream-lpr-app$ sudo find /usr/local -name libcufft.so*
thanks,
Chris
At least libcufft.so* should be found. Suggest to check CUDA installation.
Are you suggesting to reinstall these 2 sections of the install guide? https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html:
Install NVIDIA driver 470.63.01
Install CUDA Toolkit 11.4.1 (CUDA 11.4 Update 1)
Could you share the link for above?
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#install-nvidia-driver-470-63-01
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#install-cuda-toolkit-11-4-1-cuda-11-4-update-1
basically, I would like to know which section of the installation guide I should redo.
I am using T4 VM:
$ cat /etc/os-release
NAME=“Ubuntu”
VERSION=“18.04.6 LTS (Bionic Beaver)”
$ nvidia-smi
CUDA Version: 11.4
$ dpkg -l | grep TensorRT
libnvinfer-bin 8.0.1-1+cuda11.3 amd64 TensorRT binaries
You can redo “Install CUDA Toolkit 11.4.1 (CUDA 11.4 Update 1)” . From nvidia-smi, you can check if “NVIDIA driver 470.63.01” is available.
I got Driver Version: 470.103.01
| NVIDIA-SMI 470.103.01 Driver Version: 470.103.01 CUDA Version: 11.4 |
I reran the following instruction; But still not resolved.
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pinsudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600sudo apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pubsudo add-apt-repository "deb https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/ /"sudo apt-get updatesudo apt-get -y install cuda
https://developer.nvidia.com/cuda-11-4-1-download-archive?target_os=Linux&target_arch=x86_64&Distribution=Ubuntu&target_version=18.04&target_type=deb_network
I got a lot of error messages during the install like:
W: GPG error: Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A4B469963BF863CC
E: The repository ‘Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease’ is no longer signed.
N:
Err:11 Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease
Reading package lists… Done
Failed to fetch https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/./cuda_11.6.2-1_amd64.deb Hash Sum mismatch
Hashes of expected file:
- SHA512:1ba4915fa40fdc21a5bdbadcf1abd0cb9df5ce7b40b5654c2b9690e688761160706cad46f2fbbd1b31fd083eeaee61099a9aa41f8279bccc9dc95e6617b616ad
- SHA256:5215130d80e0002c08d2daaf6de53c345132ecdb1af493dc51373b6c92808731
- SHA1:46661f399bf43ab575d2a66636230d539e6910f2 [weak]
- MD5Sum:8867883a511e226111f843dd0c3118ee [weak]
- Filesize:2392 [weak]
Hashes of received file:
- SHA512:5d5aac4ba50da9f37927a0bb72c3a16bd8b64abb8784fd50105fbf595d4d3f12cef041c27b5f8d320bdbc485aefdf40a3d0b79bff09e5e96a8bc7c05e0a36e08
- SHA256:634d8318e0612bf6654d4c75831f88da491411056500caab68e1146d2295020e
Refer to GPG error: http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 - #3 by pablete
Try:
$ sudo apt-key del 7fa2af80
$ sudo apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64/3bf863cc.pub
More error or question, you can search in that CUDA forum or create a topic on it. Thanks.
Thank you Morganh. The good news is that we resolved the missing libcufft.so issue. But look like there is still Cuda error. Below is the output from the app:
attcloud@deepstream-dev-02-vm:~/deepstream_lpr_app/deepstream-lpr-app$ ./deepstream-lpr-app 1 2 0 /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_qHD.mp4 output.264
Now playing: 1
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
WARNING: [TRT]: TensorRT was linked against cuBLAS/cuBLAS LT 11.5.1 but loaded cuBLAS/cuBLAS LT 110.9.2
Running…
qtdemux pad video/x-h264
Cuda failure: status=1 in cuResData at line 316
Cuda failure: status=1 in cuResData at line 348
Frame Number = 1 Vehicle Count = 0 Person Count = 0 License Plate Count = 0
Frame Number = 2 Vehicle Count = 0 Person Count = 0 License Plate Count = 0
Cuda failure: status=1 in cuResData at line 337
Frame Number = 3 Vehicle Count = 0 Person Count = 0 License Plate Count = 0
This is the new Cuda info:
attcloud@deepstream-dev-02-vm:~$ nvidia-smi
Wed May 11 08:46:12 2022
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 Tesla T4 On | 00000001:00:00.0 Off | Off |
| N/A 31C P8 14W / 70W | 0MiB / 16384MiB | 0% Default |
| | | N/A |
I am afraid there is still something mismatching/wrong in GPU driver and CUDA.
See Quickstart Guide — DeepStream 6.3 Release documentation
Could you please try to use a docker image provided by deepstream?
See Docker Containers — DeepStream 6.3 Release documentation
You can pull nvcr.io/nvidia/deepstream:6.0.1-devel
The VM install is easier for development and integration. Let me try to fix the install some more.
