• Hardware Platform (Jetson / GPU) A30
• DeepStream Version 8.0
• TensorRT Version 10.0
**• Issue: Unable to reach HigherFPS with Current Engine, even with higher nvinfer batch size.
Title: How to configure TensorRT/DeepStream batch size to maximize throughput (>1300 FPS target)
I am trying to optimize inference throughput for my ONNX model integrated into DeepStream. My goal is to understand how TensorRT engine configuration (min/opt/max batch size, streams) and DeepStream nvinfer batch size relate to achieving higher FPS, ideally above 1300 FPS.
DeepStream nvinfer configuration
Below is my current ds_demux_pgie_config.txt:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=folded.onnx
model-engine-file=model_b100_gpu0_fp16.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=100
network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
workspace-size=16384
#parse-bbox-func-name=NvDsInferParseYolo
parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.35
topk=300
Batch size in DeepStream is currently set as:
batch-size=100
minShapes=1, optShapes=50, maxShapes=100 (during engine build)
TensorRT Performance (trtexec)
Without --streams:
Throughput: ~774.9 QPS
Mean Latency: ~1.48 ms
GPU Compute Time (mean): ~1.28 ms
Coeff of variance: ~18.8%
With --streams enabled:
Throughput: ~1379.2 QPS
Mean Latency: ~6.0 ms (note: parallel streams, latency less reliable)
GPU Compute Time (mean): ~5.76 ms
Coeff of variance: ~12.6%
My Question
Given the above QPS results and DeepStream nvinfer settings:
How should I set TensorRT engine batch sizes (min/opt/max) and DeepStream
nvinferbatch-size to maximize GPU utilization and achieve >4000 FPS throughput? -
How does the trtexec QPS (with vs. without streams) translate into real DeepStream FPS when the engine is deployed?
Is there a recommended formula or rule of thumb for choosing batch size so that throughput scales without hitting diminishing returns (e.g., higher latency or inefficient GPU scheduling)?
Does using multiple inference streams at the TensorRT level map effectively when DeepStream batches frames, or should one rely more on larger DeepStream batch-size instead?
Any guidance or best practices from the NVIDIA team or the community would be very helpful.
Thank you
