david38
September 13, 2022, 12:28pm
1
• Hardware Platform : Jetson
• DeepStream Version: 6.0
• JetPack Version (valid for Jetson only): 4.6.1-b110
hello, I trained an yolov3 on kitti using TAO, on azure cloud. Now i have the following problem, when trying to run the model on deepstream, on xavier:
0:05:17.146164547 12439 0x2fd26e60 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /home/xavier/Downloads/yolov4_resnet18_fp32_epoch_080.etlt_b1_gpu0_fp32.engine successfully
INFO: [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT Input 3x384x1248
1 OUTPUT kINT32 BatchedNMS 1
2 OUTPUT kFLOAT BatchedNMS_1 200x4
3 OUTPUT kFLOAT BatchedNMS_2 200
4 OUTPUT kFLOAT BatchedNMS_3 200
0:05:17.265996982 12439 0x2fd26e60 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:05:17.711518430 12439 0x2f714280 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 1]: Could not find output coverage layer for parsing objects
0:05:17.711775850 12439 0x2f714280 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 1]: Failed to parse bboxes
Morganh
September 13, 2022, 2:09pm
2
Moving to TAO forum.
Could you share the config file?
david38
September 13, 2022, 2:29pm
3
This is the config file
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#model-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel
#proto-file=../../../../samples/models/Primary_Detector/resnet10.prototxt
#model-engine-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
#labelfile-path=../../../../samples/models/Primary_Detector/labels.txt
#int8-calib-file=../../../../samples/models/Primary_Detector/cal_trt.bin
tlt-encoded-model=/home/xavier/Downloads/yolov4_resnet18_fp32_epoch_080.etlt
tlt-model-key=nvidia_tlt
labelfile-path=README1.txt
force-implicit-batch-dim=1
batch-size=1
network-mode=0
num-detected-classes=3
interval=0
gie-unique-id=1
output-blob-names=BatchedNMS
#scaling-filter=0
#scaling-compute-hw=0
cluster-mode=2
[class-attrs-all]
pre-cluster-threshold=0.2
topk=20
nms-iou-threshold=0.5
david38
September 16, 2022, 12:37pm
5
I have the following error nvdsinfer_custombboxparser_tao.cpp:25:10: fatal error: nvdsinfer_custom_impl.h: No such file or directory #include "nvdsinfer_custom_impl.h" when trying to compile libnvds_infercustomparser_tao.so
Morganh
September 16, 2022, 2:46pm
6
It might be related to your environment. Please check the github’s Prerequisites.
Or you can try some older branches.
david38
September 16, 2022, 3:31pm
7
Yeah, solved that one. Now I have some pyds error… AttributeError: module 'pyds' has no attribute 'gst_buffer_get_nvds_batch_meta'.
Morganh
September 16, 2022, 5:02pm
8
Suggest you to double check the environment. If it is a deepstream issue, please create topic in Deepstream forum instead.
system
Closed
October 10, 2022, 8:50am
9
