• Hardware Platform (Jetson / GPU) : RTX 4070
• DeepStream Version : 6.4
• Issue Type( questions, new requirements, bugs): Question
I’m trying to run 3 stage detector model. Here’s the latency report. The problem is after displaying on screen(nvosd->sink) for few seconds there is a lag. However in the latency report I don’t see that. I’m using rtmp stream.
Here the code snippet for creating source bin
static GstElement *
create_source_bin(guint index, gchar *uri)
GstElement *bin = NULL, *uri_decode_bin = NULL;
gchar bin_name[16] = {};
g_snprintf(bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new(bin_name);
/* Source element for reading from the uri.
* We will use decodebin and let it figure out the container format of the
* stream and the codec and plug the appropriate demux and decode plugins. */
if (PERF_MODE)
uri_decode_bin = gst_element_factory_make("nvurisrcbin", "uri-decode-bin");
g_object_set(G_OBJECT(uri_decode_bin), "file-loop", TRUE, NULL);
else
uri_decode_bin = gst_element_factory_make("uridecodebin", "uri-decode-bin");
if (!bin || !uri_decode_bin)
g_printerr("One element in source bin could not be created.\n");
return NULL;
/* We set the input uri to the source element */
g_object_set(G_OBJECT(uri_decode_bin), "uri", uri, NULL);
/* Connect to the "pad-added" signal of the decodebin which generates a
* callback once a new pad for raw data has beed created by the decodebin */
g_signal_connect(G_OBJECT(uri_decode_bin), "pad-added",
G_CALLBACK(cb_newpad), bin);
g_signal_connect(G_OBJECT(uri_decode_bin), "child-added",
G_CALLBACK(decodebin_child_added), bin);
gst_bin_add(GST_BIN(bin), uri_decode_bin);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad(bin, gst_ghost_pad_new_no_target("src", GST_PAD_SRC)))
g_printerr("Failed to add ghost pad in source bin\n");
return NULL;
return bin;
Here’s how the pipeline is arranged:
gst_bin_add_many(GST_BIN(pipeline), queue1, pgie, queue2, tracker, queue3, sgie1, queue4,
sgie2, queue5, nvdslogger, queue6, nvvidconv, queue7, nvosd, queue8, sink, NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvdslogger -> nvtiler -> nvvidconv -> nvosd
* -> video-renderer */
if (!gst_element_link_many(streammux, queue1, pgie, queue2, tracker, queue3, sgie1, queue4,
sgie2, queue5, nvdslogger, nvvidconv, queue7, nvosd, sink, NULL))
g_printerr("Elements could not be linked. Exiting.\n");
return -1;
Any suggestion on this is highly appreciated. @fanzh @Morganh
log_14_rtsp.txt (2.3 MB)
