The pipeline works at about 32fps when a file is used as a source. However when I try to use an rtsp camera frame rate is about 20 for the first 1000 frames and then drops to 3.
nvstreammux is created using the following properties:
Is this expected behaviour? I’m a beginner with DeepStream pipeline and trying to use it for production as nothing else seems to work a device as small as a Nano.
These are the messages I receive after setting GST_DEBUG=3:
FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc0:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Opening in BLOCKING MODE
0:00:04.928043540 17264 0x7ef40030f0
WARN v4l2 gstv4l2object.c:4476:gst_v4l2_object_probe_caps:nvv4l2decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
